GSR throttle cable on LS engine
I recently bought a gsr shell and put an LS engine in it and the throttle cable does not mount up correctly and bareley gives me 45% throttle. Is there a bracket I can buy?
the gsr cable is to long. u need either the ls or use a type r one. and if the gsr one does work u would probaly need a p75 bracket. but u gonan have a lot of extra slack
i dont think it will work , you will need a ls cable and bracket, i did ls w/ gsr swap and had bracket, had to get a new gsr cable and it fit perfect, only took like 3 minutes to do?
