help am new
Old Apr 8, 2007 | 08:51 PM
tbuck23's Avatar
Default help am new
ok here it's. when i start my car the rvp a 2000 rpm and it still there, and then when u step on the gas it boog out i check the tps fine the iac repalce it whatelse could it be
Old Apr 9, 2007 | 11:22 AM
Perfectionist's Avatar
Default Re: help am new (tbuck23)
Stating year and model helps, any mods or stock, etc.
Anyway, I suspect a vacuum leak. Check the vacuum hoses for cracking and leaking.
Old Apr 9, 2007 | 01:26 PM
tbuck23's Avatar
Default Re: help am new (Perfectionist)
it's 94 honda civic dx were can i find the vacuum hoses but when i put my ear but the tb i can hear a loud sucking noise i replace the tb gaseit
Old Apr 9, 2007 | 02:00 PM
1d10t's Avatar
could be a bad MAP sensor. However unlikely. spray some carb cleaner over your vacuum lines, while engine is running, to see if the cars idle changes. ( will be noticably). try unplugging IACV.
Justinmnhall
22
Sep 6, 2013 03:40 PM
daibloblanco
Apr 29, 2008 06:32 PM
Linh.
Jul 3, 2006 09:08 PM
I Like Hondas
Jun 11, 2006 05:35 PM
JDM_SOHC
Apr 12, 2005 07:05 AM
