91 accord misses/hesitates under light load between 1500-2000 rpm
Old Apr 8, 2007 | 08:34 PM
tvu's Avatar
tvu
Default 91 accord misses/hesitates under light load between 1500-2000 rpm
91 accord misses/hesitates under light load between 1500-2000 rpm. this only happens when car is warmed up. engine idles perfect and accelerates perfectly with the miss/hesitation when rpm hits 1500-2000. checked everthing from cap, rotor, plugs, injector, throttle plate, iac. running out of option.
Old Apr 8, 2007 | 10:22 PM
Twixle's Avatar
ate my pixel
Default Re: 91 accord misses/hesitates under light load between 1500-2000 rpm (tvu)
wires?
Old Apr 9, 2007 | 03:50 AM
hondamanwill's Avatar
you may need to clean EGR passages. These are the small plug on the intake manifold this cause miss at the RPM's you are talking about.
Old Apr 9, 2007 | 05:07 PM
tvu's Avatar
tvu
Default Re: (hondamanwill)
do I just remove the egr and clean the holes? or is there a different port that needs to be cleaned?
Old Apr 9, 2007 | 05:08 PM
tvu's Avatar
tvu
checked wires as well and they are fine.
Old Apr 9, 2007 | 05:28 PM
Conflicted's Avatar
Perhaps the fuel filter?
Old Apr 9, 2007 | 05:49 PM
tvu's Avatar
tvu
Default Re: (Mani Fresh)
ill check on the fuel filter.
Old Apr 9, 2007 | 05:55 PM
rsvmille's Avatar
Default Re: (tvu)
Most likely the egr valve. to test dissconnect the egr valves vacuum hose and test again. If the hesitation goes away then thats it. To fix, you'll need to drill out the brass plugs in the intake manifold behind the injectors then clean the carbon deposits in the egr passages. 4-6 plugs depending on the model. Also make sure to clean all the way through, right beneath the plug is a smaller hole that is sometimes missed. Once cleaned there are plugs from the dealer that can tap back in place of the old ones. Dealer has a slide hammer kit with drill bit and tap that makes it very simple to do.
Old Apr 9, 2007 | 06:05 PM
welldun's Avatar
Default Re: (rsvmille)
yeah i had the same problem..drilling sucks so i took the egr valve off and used my sons paintball gun cleaner probe thing (it looks like a spiral wound piece of plastic) and used brake cleaner ..it took about 4 rags of crap but i eventually got all the carbon out without drillin any holes. when you get done with this warm up the car pull the pcv vacuum hose off and stick it in a can of seafoam , let it choke off the engine...wait 20 minutes and then rod the hell out of it...sheel run great then
Old Apr 10, 2007 | 07:25 PM
here guys now stop trying everything that isn't going to work.:
98-074
December 8, 1998
Applies To: 1990-93 Accord - ALL
Hesitation or Stumble
(Supersedes 98-074, dated October 6, 1998)
SYMPTOM
An engine hesitation or stumble can be felt under light acceleration between 1,500 and 2,000 rpm.
PROBABLE CAUSE
Carbon build-up has restricted the EGR ports into the intake manifold runners.
CORRECTIVE ACTION
Clean the carbon out of the EGR ports.
PARTS INFORMATION
O-ring: P/N 16077-PR3-005, H/C 3147568
O-ring: P/N 91304-PE2-005, H/C 1869460
Gasket: P/N 36455-PT3-A01, H/C 3583697
[NEW] EGR port plugs: P/N 17199-PT3-AHM, H/C 6078596
Grey_accord
Nov 23, 2012 04:12 PM
91hondaaccord
Oct 24, 2011 06:19 PM
gator-dog
Jan 16, 2005 03:02 PM
slwh22accord
Nov 27, 2004 05:59 AM
KEVlN
Mar 5, 2004 05:50 AM
