How to clean valves?
Old Apr 8, 2007 | 08:33 PM
boomersz's Avatar
Default How to clean valves?
how do you go about cleaning the valves and the surrounding area w/out removing them?
picture for refference
Old Apr 8, 2007 | 09:18 PM
soulpwr's Avatar
Default Re: How to clean valves? (owner)
Hot tank it.
Old Apr 9, 2007 | 03:46 AM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owner &raquo;</TD></TR><TR><TD CLASS="quote">how do you go about cleaning the valves and the surrounding area w/out removing them?
Wire wheel on a drill.But you really should disassemble it and do it right.And don't hot tank it all assembled.It will ruin the seals and leave solvent in the guides.
Old Apr 9, 2007 | 04:50 AM
mmuller's Avatar
Mad Scientist
Default Re: How to clean valves? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">
Wire wheel on a drill.But you really should disassemble it and do it right.And don't hot tank it all assembled.It will ruin the seals and leave solvent in the guides.</TD></TR></TABLE>
Old Apr 9, 2007 | 07:23 AM
dpaton's Avatar
Oops. Ultrasonic cleaning is only for disassembled heads. Sorry...skimmed the OP, and missed the part about keeping it assembled.
Modified by dpaton at 9:16 AM 4/9/2007
Old Apr 9, 2007 | 08:09 AM
arc_55's Avatar
wire wheel is probably the easiest and safest way with the head assembled. Although you should do it proeprly and have it disassembled and check your seats and guides at the same time.
Old Apr 9, 2007 | 11:18 AM
excivicboy96's Avatar
Default Re: (arc_55)
If you took it apart is there a solvent to soak individual parts in to loosen the gunk?
Old Apr 9, 2007 | 11:42 AM
dpaton's Avatar
Default Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">If you took it apart is there a solvent to soak individual parts in to loosen the gunk?</TD></TR></TABLE>
The best way to do it if you have the head apart is to take it to a shop for ultrasonic cleaning. That will not only get the carbon off, but it'll help clean out the water passages and the oil drainbacks.
tightenup
Apr 17, 2013 09:29 PM
defnu
10
Mar 11, 2008 05:49 PM
boomersz
Apr 9, 2007 11:35 AM
Boostage
15
Apr 9, 2006 04:35 AM
thaiphob
Dec 2, 2005 01:15 PM
