Removing Crank Pulley Bolt
Old Apr 8, 2007 | 06:28 PM
kornerk12's Avatar
Default Removing Crank Pulley Bolt
I have the tool to hold back but that thing isnt budging, i can see the 1/2 breaker bar with a pipe on it bending and dont want to snap it. I have heard its not ok to use an impact gun on these. Is that just for tightening or both tightening and loosening ?
Old Apr 8, 2007 | 06:59 PM
SteveoBA8's Avatar
Default Re: Removing Crank Pulley Bolt (kornerk12)
Using an impact to for tightening is a bad idea, torque it to 181 ftlbs.
My 1/2 snap on breaker bar was bending also with a 3ft cheater bar. Just keep at it. I slide the pipe all the way over the bar just in case. Mine made a loud crack when it finally broke loose.
Old Apr 8, 2007 | 08:07 PM
TruNinja619's Avatar
just use an impact gun on it... the bolt is suppose to be torqued to 181 ft/lbs... so using a breaker bar is just a waste of time...
Old Apr 8, 2007 | 08:14 PM
RAB's Avatar
RAB
Default Re: Removing Crank Pulley Bolt (TruNinja619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 &raquo;</TD></TR><TR><TD CLASS="quote">just use an impact gun on it... the bolt is suppose to be torqued to 181 ft/lbs... so using a breaker bar is just a waste of time...</TD></TR></TABLE>
Ditto, I used an impact gun before, not a problem, however...bolt it on as tight as you can with conventional tools then hit it with the impact a couple of times.
Old Apr 8, 2007 | 08:53 PM
h23vtak's Avatar
haha, mine came un torqued for me....lol broke my lower crank pully and those belts came off..... I fixed it but i dont think it hurt my crank or anything
Old Apr 9, 2007 | 03:35 AM
hu's Avatar
hu
Does it come off clockwise or counter clockwise?
Recently I was reading of some bolt on the engine that came off counter clockwise. Could be wrong.
Old Apr 9, 2007 | 03:57 AM
flyrod's Avatar
Default Re: (hu)
It is a normal thread. The only left hand threads I know of on the prelude are on the diff, and they have little arrows.
Old Apr 9, 2007 | 06:15 AM
kulrevon's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Does it come off clockwise or counter clockwise?
Recently I was reading of some bolt on the engine that came off counter clockwise. Could be wrong.</TD></TR></TABLE>
Normal way to come off is counter clockwise. (righty-tighty, lefty-loosey)
And the crank bolt has normal threads.
Old Apr 9, 2007 | 06:30 AM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 &raquo;</TD></TR><TR><TD CLASS="quote">just use an impact gun on it... the bolt is suppose to be torqued to 181 ft/lbs... so using a breaker bar is just a waste of time... </TD></TR></TABLE>
how can you say that? i watched a guy with an impact gun trying to bust one of my spindle nuts loose. he gave up with the impact gun and was like, "i dont know what you want me to do". i said, "why dont you use a breaker bar?" and he laughed and said it wouldnt make a difference. i asked him for a length of pipe, and it was about 4'. 36mm socket on a 1/2" drive and it was loose with one push. then i laughed at him.
Old Apr 9, 2007 | 06:32 AM
Revi's Avatar
Default Re: Removing Crank Pulley Bolt (bluedlude)
Breaker Bar = FTW
Old Apr 9, 2007 | 06:35 AM
Mudlocked's Avatar
I had this same problem about 2 weeks ago.
Mine ended up being cross threaded from the previous owner. We ended up having to use a 3/4inch drive impact wrench that put out 2,000lb/tq(normally used for heavy construction equipment), and it ended up snapping the bolt. That was a PITA!
Old Apr 11, 2007 | 03:50 PM
kulrevon's Avatar
Default Re: (Mudlocked)
the other night I broke 2 1/2 breaker bars and a 1/2 snap on 3 ft ratching breaker bar. I broke them on 36mm axle nuts but I did break them. Where as the impact gun took them off.
If you have a "good" impact gun it is better then a breaker bar.
Old Apr 11, 2007 | 06:59 PM
lude98SH's Avatar
Default Re: (kulrevon)
I actually snapped a 1/2 drive prolly like 24 inch huskey breaker bar a few weeks ago trying to break an axle nut loose lol i had like a 7 ft piece of pipe on it and it wasnt moving. I went from like a 2 foot piece to a 4 to a 7 and nothing broke that sucker loose. I went a got an impact and got it off in like 5 mins.
Old Apr 12, 2007 | 06:54 AM
slammed95lude's Avatar
Default Re: (lude98SH)
I have used both methods, if you have a good impact it will work try using a 700ft lb in reverse impact, that is a good method if the breaker won't work.
Old Apr 12, 2007 | 09:18 AM
marks_lude's Avatar
Default Re: (slammed95lude)
ive done it both ways. both times between trying... i heated it up with a torch also between trys. helps sum, but dont heat the f**k out of it.
Old Apr 15, 2007 | 12:11 AM
kornerk12's Avatar
Default Re: (marks_lude)
propane or oxy-acetalyn (cant spell) ? I have a propane torch but idk if it will heat it enough ?
Old Apr 15, 2007 | 05:49 PM
kornerk12's Avatar
Default Re: (kornerk12)
well i just tried a 500 ft lbs impact and that thing isnt moving. Who makes a 1000 ft lbs gun besides Ingersaw rand, mac or snap on ? How much does the IR run $$$ ?
Old Apr 15, 2007 | 06:09 PM
hu's Avatar
hu
Try to tighten it, then reverse it. I used my Dewalt electric impact wrench today to remove the crank pulley bolt. I had to keep it on there for 3 minutes before it broke loose. The Dewalt has 345lbs of tq.
If you need a stronger impact, get an electric one from Harbor freight tools. Thats the cheapest place I can think of.
Old Apr 15, 2007 | 06:23 PM
kornerk12's Avatar
Default Re: (hu)
I have a craftsman electric impact same exact specs as the dewalt and had it on there was about 2 mins and nothing. Heated the bolt and nothing.
I was thinking of getting that earthquake impact from harbour freight but it only goes to 625 ft lbs for $50 more i can get a husky that goes to 700. And the electric one i have is stronger than the harbour freight ones ive seen.
It just pisses me off that whoever took this off before prolly got their gun and just bottomed it out on the threads. What is it supposed to be torqued to anyway.. like 180 ft lbs ???
Old Apr 15, 2007 | 06:25 PM
hu's Avatar
hu
181 ft lbs.
Put that impact back on there and just drill that *****. I had it on there for 3 minutes straight until it broke loose.
Old Apr 15, 2007 | 06:47 PM
kornerk12's Avatar
Default Re: (hu)
wow that sucker just sat there didnt budge. I can get a 3/4 inch gun you think i could mess anything up using something like that ?
Old Apr 15, 2007 | 07:37 PM
117's Avatar
117
Never had a problem once I started using a 3/4" drive breaker bar. I use 3/4" F to 1/2" M impact adapters from NAPA. I've broken a few (3 or 4), but I haven't had a driveshaft nut or crank pulley bolt yet that I haven't been able to get off using this breaker bar. It's about 3.5 ft long, and I've had to use a ton of torque to get some bolts/nuts off, but it works.
MagicUnicorn
24
Apr 28, 2022 02:45 PM
c61lude
Dec 2, 2018 12:06 PM
1Digger
Aug 7, 2010 09:43 AM
jbell
20
Jan 1, 2005 09:09 PM
BoostedH23Accord
Jul 13, 2004 05:50 PM
