How would I hard-wire my cell phone adapter to my car?
Old May 27, 2002 | 09:11 AM
harryg's Avatar
Default How would I hard-wire my cell phone adapter to my car?
Eh.. Instead of using the cigarette adapter every time, I had the grand idea of hardwiring the adapter to my car, so it'd free up my cigarette lighter. I snipped the cigarette adapter to the phone, which left two wires (+ and ground). I spliced them into the constant line that is always on as long as the battery is connected. The cell phone showed activity in regards to the adapter (it was charging), and then I began to smell something funny and realized that the phone was getting extremely hot. An electrician I am not.
What must I do in order to get this 'excellent' idea of mine to work?
[Modified by harrytg, 6:25 PM 5/27/2002]
Old May 27, 2002 | 09:40 AM
tegtyper's Avatar
Default Re: How would I hard-wire my cell phone adapter to my car? (harrytg)
Inside the cig plug you cut off, was likely a voltage regulator which converted the 12V to 6 or 9 volts or something. There could have even been some charge circuitry specific to your battery type.
You likely overcharged your battery. *Probably* didnt do too much damage if your battery is a nickel type (NiCd or NiMh). Lithium Ions generally dont like to be overcharged. You may want to replace the battery to be safe
Old May 27, 2002 | 10:57 AM
PupaScoopa's Avatar
I would have recommended soldering your supply power directly to the cig. lighter plug (to use it's circuitry). Rarely can you damage a battery by overcharging since it's the phone that controls what the battery gets... this means your phone might be toast!
Old May 27, 2002 | 12:52 PM
harryg's Avatar
Default Re: How would I hard-wire my cell phone adapter to my car? (PupaScoopa)
My phone works fine, as far as I know. It was only 'charged' for a few seconds to make sure that it 'worked'. Thanks for the advice.
Old May 27, 2002 | 11:08 PM
tuphatt's Avatar
A word from the somewhat wise.
USE A FUSE in the line.
I once knew this guy who did an install with strobes and forgot to fuse his line and well he needed a new hood and motor. Evidently his car caught on fire.
Old May 28, 2002 | 02:43 AM
harryg's Avatar
Default Re: How would I hard-wire my cell phone adapter to my car? (tuphatt)
hahah, well noted
tommy boy2
Sep 9, 2018 01:11 PM
crxaddikt
Apr 5, 2009 01:45 PM
VTecLude1994
14
May 27, 2007 03:40 PM
Undercover_Skank
15
Jan 28, 2007 10:08 PM
JCritt
17
Nov 28, 2004 09:46 AM
