Question on Turbo-ing?
Old Apr 8, 2007 | 01:41 PM
keegur's Avatar
Default Question on Turbo-ing?
ok i know almost everything that i have to get , but there is one thing that i dont understand, how does the oil feed work and all that,please someone explain to me , everything about the oil, like how it gets to the turbo , where t run lines from and to
Old Apr 8, 2007 | 01:43 PM
Luserkid's Avatar
Default Re: Question on Turbo-ing? (keegur)
To make it easy on you get the golden eagle oil adapter.
Old Apr 8, 2007 | 01:48 PM
keegur's Avatar
Default Re: Question on Turbo-ing? (Luserkid)
thats not my question, my main question is how does the oil get to the turbo , do i have to buy some sort of pump ?
Old Apr 8, 2007 | 01:50 PM
spork motorsports's Avatar
* B A N N E D *
pressure from the block to the turbo, back into the oil pan,
you t off the oil pressure sensor, attach to the oil feed nipple on the turbo then add a drain back into a drilled and tapped oil pan with a fitting
Old Apr 8, 2007 | 01:54 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keegur &raquo;</TD></TR><TR><TD CLASS="quote">thats not my question, my main question is how does the oil get to the turbo , do i have to buy some sort of pump ?</TD></TR></TABLE>
It works the same way the engine's oiling system works. The oil pump pressurizes lines that feed the center cartridge and a drain line allows said oil to be evacuated at a steady pace via gravity. Be sure to install a pressure restriction in the feed line.
Old Apr 8, 2007 | 01:58 PM
keegur's Avatar
how does the golden eagle adapter work/ where does it go?
Old Apr 8, 2007 | 02:00 PM
keegur's Avatar
ohh by the way thank you guys so much, it answered so much for me
Old Apr 8, 2007 | 03:28 PM
sauceja's Avatar
Default Re: (keegur)
http://www.homemadeturbo.com
You should be able to "search" there and find some info.
Old Apr 8, 2007 | 03:54 PM
confucioussae's Avatar
Default Re: (sauceja)
the oil is usually tapped from one of two places, both are pressurized already. some people T off of the oil pressure sender on the back of the block (near the filter). like luserkid said, the better way to go is to use a sandwich adapter. the GE ones are quality pieces, i couldnt afford one so i went with the blox sandwich.
https://honda-tech.com/zerothread?id=1886257
theres lots of info on both of these methods, search the archives
Old Apr 8, 2007 | 09:18 PM
* B A N N E D *
Default Re: (confucioussae)
i said THAT!!!!!!! luserkid said to buy a kit!!!!!!
ting off is free/better imo
EK k kay
Oct 5, 2005 03:07 PM
1gEF-8
11
Aug 18, 2005 03:13 PM
2phast
May 11, 2005 12:57 PM
wade
May 17, 2004 08:24 PM
Bnjmn
Oct 5, 2003 03:49 PM
