Heating Problem
Do anybody know what this problem is?
if I am riding on the highway between 70-85
the car what to start overheating I cut the
heat on it goes back down, but when I take
back way's home under 65mph its fine I am in
traffic and everything it doesn't overheat, only
at high speed it start to want to overheat
(and I check to see if it had a blown
headgasket it doesn't I look for a milkey white at the
tip of the oil dip stick)
DO ANYBODY KNOW WHAT THIS IS?
It is not a 100% guarantee that it is the thermostat. It could be a clogged cooling passage or bad water pump among other things. The thermostat is a good place to start.
Here is a follow-up question. Does it still get as hot at 75-80 MPH if the heater is on hot with the blower going?
Dogginator if I cutt the heater on it goes back down to normal temp.
what I am going to do is
1) Replace the Raditor Cap
2) Flush the Raditor put new coolent in it
3) Replace thermostat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kennyboi »</TD></TR><TR><TD CLASS="quote">Dogginator if I cutt the heater on it goes back down to normal temp.</TD></TR></TABLE>
That also supports a bad thermostat. The heater core is not plumbed through the thermostat, so its use provides additional cooling.
Your plan of attack seems sound.
mines does it after 60 mph, when i turn on the heat it cools it down a little bit but im in south florida so i can be driving around with the heat on when it allready 85+...i think my headgasket isnt blown but has a leak i see a small about of oil grudge that builds up over time between the block and head.
and i was doing some research about it being the water pump and a guy was saying he has been working on honda's for 15 years and never seen a water pump go on a honda that hasnt leaked first..
Papichulo1767
11
Mar 1, 2008 07:08 AM
SLO Sol
Feb 28, 2006 07:19 AM
