could the thermostate be going bad?
When i start the car it goes up to H then it sits there i start worrying then it just goes down to the usual temp? now this only happens when its been freezing out side the night before, and im wondering if i need to change the antifreeze but its neon green. then i thought maybe the thermostate is bad since its burning heat when its close to H. any ideas?
Re: could the thermostate be going bad? (D-money CX)
I'd say wait till it warms up, see if you have the problem still. If the problem still occurs, change your thermostat.
Re: could the thermostate be going bad? (rleonekc)
if it gets hot right when u start ur car, your temperature sensor could be bad, use a hydrometer to check ur coolant and check ur temperature range of it. If the problem persists flush ur system. peace
