Heating Problem
Old Apr 8, 2007 | 06:46 AM
kennyboi's Avatar
Default Heating Problem
Do anybody know what this problem is?
if I am riding on the highway between 70-85
the car what to start overheating I cut the
heat on it goes back down, but when I take
back way's home under 65mph its fine I am in
traffic and everything it doesn't overheat, only
at high speed it start to want to overheat
(and I check to see if it had a blown
headgasket it doesn't I look for a milkey white at the
tip of the oil dip stick)
DO ANYBODY KNOW WHAT THIS IS?
Old Apr 8, 2007 | 07:49 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Heating Problem (kennyboi)
It could be that your thermostat isn't fully opening. Also, what is the coolant level in your overflow bottle?
Old Apr 8, 2007 | 07:57 AM
kennyboi's Avatar
in between min and max.
Old Apr 8, 2007 | 08:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (kennyboi)
This is looking like a thermostat. Does your temperature vary when the car is driven in low speed traffic once it is warm?
Old Apr 8, 2007 | 09:15 AM
kennyboi's Avatar
thats what crazy when I am in traffic is stay on the cool side the only time it start to over heat is when I am on the highway doing 70-85.
Old Apr 8, 2007 | 09:36 AM
Dogginator's Avatar
Daisy... Daisy...
The load is higher as is the engine speed at 75-80. If the thermostat isn't fully opening, the cooling capacity would be reduced, especially at higher RPM.
Old Apr 8, 2007 | 10:45 AM
kennyboi's Avatar
^^^ so that mean it the thermostat then
THANKS FOR EVERYBODY HELP.
Old Apr 8, 2007 | 11:11 AM
m3 boostin's Avatar
my car is doing the same thing, i changed the t-stat and still doing the same thing i think its my headgasket
Old Apr 8, 2007 | 12:02 PM
Dogginator's Avatar
Daisy... Daisy...
It is not a 100% guarantee that it is the thermostat. It could be a clogged cooling passage or bad water pump among other things. The thermostat is a good place to start.
Here is a follow-up question. Does it still get as hot at 75-80 MPH if the heater is on hot with the blower going?
Old Apr 8, 2007 | 01:49 PM
kennyboi's Avatar
Default Re: (m3 boostin)
m3 boostin at the tip of your oil dip stick is it a white like milkey at the tip
of it.
Old Apr 8, 2007 | 01:51 PM
kennyboi's Avatar
Default Re: (Dogginator)
Dogginator if I cutt the heater on it goes back down to normal temp.
what I am going to do is
1) Replace the Raditor Cap
2) Flush the Raditor put new coolent in it
3) Replace thermostat
Old Apr 8, 2007 | 02:25 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kennyboi &raquo;</TD></TR><TR><TD CLASS="quote">Dogginator if I cutt the heater on it goes back down to normal temp.</TD></TR></TABLE>
That also supports a bad thermostat. The heater core is not plumbed through the thermostat, so its use provides additional cooling.
Your plan of attack seems sound.
Old Apr 8, 2007 | 02:51 PM
m3 boostin's Avatar
mines does it after 60 mph, when i turn on the heat it cools it down a little bit but im in south florida so i can be driving around with the heat on when it allready 85+...i think my headgasket isnt blown but has a leak i see a small about of oil grudge that builds up over time between the block and head.
Old Apr 8, 2007 | 02:54 PM
m3 boostin's Avatar
and i was doing some research about it being the water pump and a guy was saying he has been working on honda's for 15 years and never seen a water pump go on a honda that hasnt leaked first..
Old Apr 8, 2007 | 05:24 PM
kennyboi's Avatar
my water pump is not that old but ill have it check 2
Old Apr 9, 2007 | 09:45 AM
kennyboi's Avatar
I also forgot to add that the over flow was full
when I pulled over.
Old Apr 9, 2007 | 10:55 AM
SickIntegraWon's Avatar
usually its the thermostat when your cars temp goes up and down, try that or the coolant temp sensor..
Papichulo1767
11
Mar 1, 2008 07:08 AM
b0dteg
Dec 16, 2007 05:27 PM
SLO Sol
Feb 28, 2006 07:19 AM
jmkc
Nov 5, 2005 09:24 AM
bigmike
Jun 14, 2002 08:14 PM
