HELP:air/fuel guage on lean side
Old Apr 7, 2007 | 07:14 PM
honda_tuner_2007's Avatar
Default HELP:air/fuel guage on lean side
i just bought a 97 civic dx hatch with a 95 gsr swap and type r ecu and is has a air/fuel guage and it was always kinda on the lean side and now its always in the red(lean side).how do you fix that?i know its not good to drive it when its so lean.
Old Apr 7, 2007 | 08:31 PM
arc_55's Avatar
Is this a wideband 02 gauge or just a standard narrow band?
Old Apr 7, 2007 | 08:55 PM
racin_jayson's Avatar
If it's a narrow band don't fret, those are very inacurate, but when you get on the gas it should sweep over to the green side still.
Old Apr 8, 2007 | 06:13 AM
ludecz's Avatar
Default Re: HELP:air/fuel guage on lean side (honda_tuner_2007)
I'd say put it on the dyno with air fuel reading, to be sure. Those narrowband gauges are only for show.
Old Apr 8, 2007 | 07:35 AM
Default Re: HELP:air/fuel guage on lean side (ludecz)
its a narrow band and when i do get on the gas it moves a little but never gets to the rich side
Old Apr 8, 2007 | 07:51 AM
arc_55's Avatar
the reason most guys are saying that the narrow bands are for show is because the stock 02 sensor only has a range from 0-1 volts. Your stock 02 sensor is constantly changing from lean to rich as it tries to modify your injector pulse width. To see the gauge go from green to red all the time is not uncommon. This is why these gauges are inaccurate becuase of the constant change of the 02 chasing the pulse width. A wideband has a much bigger range and is realistic for you to monitor.
Old Apr 8, 2007 | 08:11 AM
riceburner700's Avatar
Default Re: (arc_55)
ask the guy who sold you the car if it had any kind of ecu recalibration. and those narrow bands are just a lights display.
Old Apr 8, 2007 | 09:16 PM
PrettyLude's Avatar
i've seen this happen before with the autometer gauge, it just indicates that the o2 sensor is not good anymore.
Old Apr 9, 2007 | 11:16 AM
Default Re: (PrettyLude)
im just gonna replace the o2 sensor and then see what it does
Old Apr 10, 2007 | 08:29 AM
arc_55's Avatar
i would lab scope the 02 first before making that assumption. See what your wave signal is like, your 02 sensor could be lazy and not sending a MIL.
Old Apr 10, 2007 | 10:48 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arc_55 &raquo;</TD></TR><TR><TD CLASS="quote">Your stock 02 sensor is constantly changing from lean to rich as it tries to modify your injector pulse width.</TD></TR></TABLE>
It's constantly changing from lean-rich-lean because the ECU is actually commanding the injectors to do so. It's not like the a/f ratio just varies for the hell of it while the ECU monitors the O2 and tries to control that condition. This switching is actually needed to make the catalytic converter function properly.
And using a scope to look at your O2 sensor would indeed be the best way of troubleshooting it, rather than just outright replacing it.
honda_tuner_2007
Apr 7, 2007 09:15 PM
Teggyb18b
Dec 1, 2002 06:29 PM
tr4il
Nov 24, 2001 09:46 PM
5gen-hybrid
Aug 5, 2001 10:49 PM
