converting 1 wire 02 to a 4 wire?
Old Apr 7, 2007 | 03:39 PM
riceburner700's Avatar
Default converting 1 wire 02 to a 4 wire?
i have a 92 honda civic cx with a d15b8 that has a 1 wire 02 sensor. i installed d15b7 head and am coverting to a p06 ecu for tuning and have to run a 4 wire or else i will run a CEL. would it be easier to just get an engine harness for a maneul d15b7 or just wire up the 4 wire to my harness now?
were do all the wires go for a heated 02 sensor
Old Apr 7, 2007 | 07:56 PM
Default Re: converting 1 wire 02 to a 4 wire? (riceburner700)
bump
Old Apr 7, 2007 | 08:50 PM
racin_jayson's Avatar
I'm not 100% sure, But depending on which program you are using you should be able to disable the 02 heating system then you would just need to have the signal wire connected to the sensor. Someone correct me if I am way off....
Old Apr 8, 2007 | 08:07 AM
Default Re: (racin_jayson)
im going with the hondata s300
chrismanis
Nov 6, 2014 12:07 PM
PLMAC
Oct 18, 2008 10:12 AM
streetstylenperformance
Feb 26, 2004 03:28 PM
5STAR3
Jan 22, 2004 03:47 PM
