wierd thing happened, fuel pressure falls down
Old Apr 7, 2007 | 09:57 AM
zenon8890's Avatar
Default wierd thing happened, fuel pressure falls down
i was driving normally my boosted d15b vtec after i changed my clutch, and on the way home suddnly my car starts to bog like hell, i went to check it and the fpr gauge dropped from 45psi to 20psi. i got crazy i thought someone played with it, i turned off the car and started it again and it went back to 45psi, after driving it for a couple of miles it did the same thing, is it weak voltage to the walbro fuel pump?! or bad fuel filter? or anything else?
Old Apr 7, 2007 | 10:00 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: wierd thing happened, fuel pressure falls down (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">i was driving normally my boosted d15b vtec after i changed my clutch, and on the way home suddnly my car starts to bog like hell, i went to check it and the fpr gauge dropped from 45psi to 20psi. i got crazy i thought someone played with it, i turned off the car and started it again and it went back to 45psi, after driving it for a couple of miles it did the same thing, is it weak voltage to the walbro fuel pump?! or bad fuel filter? or anything else?</TD></TR></TABLE>
Check the voltage, replace the filter, both good starting points.
Old Apr 7, 2007 | 10:06 AM
zenon8890's Avatar
Default Re: wierd thing happened, fuel pressure falls down (Ace$nyper)
but after i turn off the car and start it again its normal, i think voltage
Old Apr 7, 2007 | 10:08 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">but after i turn off the car and start it again its normal, i think voltage</TD></TR></TABLE>
Then why not check it?
Old Apr 7, 2007 | 10:09 AM
zenon8890's Avatar
checking .......
Redprelude98
33
Apr 28, 2009 07:34 PM
riceburner700
12
Mar 14, 2007 10:58 AM
hondaracing1on12004
Dec 15, 2004 12:59 PM
Louie_EM1
Mar 6, 2004 07:05 AM
SuperRice
Apr 2, 2003 03:13 PM
