cams: '97 vs '98 vs '00
Old Apr 6, 2007 | 11:49 PM
kaj's Avatar
kaj
Default cams: '97 vs '98 vs '00
is there enough difference that it's worth the switch? i have one motor with '98 or '00 cams.. i forget which... i think it has the 98s that came in the motor.
i also have an engine with '97s.
is it worth the trouble to swap? if it's just a few whp, then i'm not gonna worry about it.
thanks
Old Apr 6, 2007 | 11:58 PM
neo_'s Avatar
Default Re: cams: '97 vs '98 vs '00 (kaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Delaney &raquo;</TD></TR><TR><TD CLASS="quote">CTR cams differ only with the 1997-1999 ITR cams at the intake VTEC lobe duration ( by only 3 degrees more duration ) and ramp angle..that's it!! The intake max. lift are identical. The exhaust cams for both are identical. :
The 2000-2001 ITR cams are identical to CTR cams.
And yet the 2000-2001 ITR's make identical power to 1997-1999 ITR's!! There's no advantage in getting CTR cams for a B18C. - about 8-10 peak whp gain properly tuned.</TD></TR></TABLE>
To summarize it up, all ITR years make the same amount of power.
Old Apr 7, 2007 | 07:48 AM
MOVE OVER's Avatar
Default Re: cams: '97 vs '98 vs '00 (neo_)
But, what about with tuning?
I have a blower on my R and I sometimes wonder what the power difference might be by switching the cams.
Old Apr 7, 2007 | 07:51 AM
Comp97GSR's Avatar
Default Re: cams: '97 vs '98 vs '00 (ITR 1102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 1102 &raquo;</TD></TR><TR><TD CLASS="quote">But, what about with tuning?
I have a blower on my R and I sometimes wonder what the power difference might be by switching the cams.</TD></TR></TABLE>
Don't you have a car to work on or something?
I could have swore that an OG member with tuning skills said he got 7whp out of CTR intake cams with tuning.
Old Apr 7, 2007 | 09:21 AM
Todd00's Avatar
I said I don't want a title!
Default Re: cams: '97 vs '98 vs '00 (Comp97GSR)
Isn't there a lot of archived information about the 97/98 vs. 00/01 cams?
Even the honda part numbers are different. But quite simply, I believe 00/01 cams are the same as the CTR cams.
Old Apr 7, 2007 | 10:32 AM
kaj's Avatar
kaj
Default Re: cams: '97 vs '98 vs '00 (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there a lot of archived information about the 97/98 vs. 00/01 cams?
Even the honda part numbers are different. But quite simply, I believe 00/01 cams are the same as the CTR cams.</TD></TR></TABLE>
i checked the thread, here in the ITR forum. 'found nothing on it, though there MUST be. so cams out of my old '00 engine would be a bit better than out of my '97?
Old Apr 7, 2007 | 03:46 PM
MOVE OVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">
John Boy,
I checked the ECU already... Unfortunately, the S300 does not act up at all on the GSR. Must be a short in the wires somewhere
B18Sleeper
Nov 1, 2005 04:05 PM
btcca4
Jun 20, 2005 09:21 PM
allmotorbeasteg6
Aug 22, 2004 07:00 AM
IC x Prince
Feb 24, 2003 09:31 AM
vtecdc2
Sep 2, 2002 07:52 PM
