b20b swap what next...
well i just got my b20 w/ a chipped p75 ecu, 00ls tranny w/ stage 2 clutch , dc header w/ 2.25 pipes.. now i'm trying to see what else i could do to make my car give out more horses i heard of the b16 head and all ... what you gys recommend...
get rid of that transmission unles u plan on going turbo.Get a type r or atlease a b16 for shorter gear ratios.And yes a vtec head will help out alot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marineplatano1 »</TD></TR><TR><TD CLASS="quote">what wrong w/ the ls tranny ? wouldn't longer gears be good for me when it comes to b20/vtech????
ill be the first to say it...its Vtec not "Vtech" and no shorter you go through the gears the quicker you will go!
</TD></TR></TABLE>ill be the first to say it...its Vtec not "Vtech" and no shorter you go through the gears the quicker you will go!
i had a b20vtec with a b16 head and it was fast as ****. i had it on a b16 tranny. if you planon staying all motor upgrade to the b16 tranny, if you're going to really get into this a build for a lot of power and a turbo kit then id go with a gsr, the gear ratio is a little longer than the b16 tranny, but a lot better than an ls.
the ls tranny is the bastard tranny of the b series.
vtech=phone... lol but yesyou need a vtec head for sure and get a b16 trans
</TD></TR></TABLE>vtech=phone... lol but yesyou need a vtec head for sure and get a b16 trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc »</TD></TR><TR><TD CLASS="quote">whatever you decide make sure you tune if you go with a vtec head. Tuning is one of the most important things when messing with a b20. </TD></TR></TABLE>
i 2nd that
i 2nd that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">ill be the first to say it...its Vtec not "Vtech" and no shorter you go through the gears the quicker you will go! </TD></TR></TABLE>
swap_killer7079
Feb 2, 2011 05:06 AM
