msd cap, rotor, coil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacob1217 »</TD></TR><TR><TD CLASS="quote"> is it worth doing the msd cap rotor, wires and coil on my 93 ex with header back exhaust and intake? </TD></TR></TABLE>
No MSD is a waste of money. Unless your making some serious power, keep your honda coil, honda uses great coils, no need to waste money on a MSD setup.
you guys should also check out http://www.summitracing.com they have an ignition upgrade for civics. comes with high output internal coil, colored/clear cap, rotor, and wires. and they also sell msd pretty cheap too.
Waste of cash unless car is making a lot of power. Just go with OEM caps, rotor and coil. Might want to get some NGK blues while your at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazy4Honda »</TD></TR><TR><TD CLASS="quote">No i dont think so stock ignition is good for up to 12 second quarter mile if you are going turbo or S/C than i might think about it?? </TD></TR></TABLE>
way faster than that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si »</TD></TR><TR><TD CLASS="quote">Waste of cash unless car is making a lot of power. Just go with OEM caps, rotor and coil. Might want to get some NGK blues while your at it.
im @ 8 psi
</TD></TR></TABLE>im @ 8 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">
No MSD is a waste of money. Unless your making some serious power, keep your honda coil, honda uses great coils, no need to waste money on a MSD setup.</TD></TR></TABLE>
@ OP:
Absolutely not worth it for your application.
@ OP:
im going 11sec on stock honda ignition. my homies running 340 boosted lsvtec on stock ignition. you really dont need it unless you really want the options like 2 step, boost retard
Thanks for the opinions guys. I've heard that hondas have weak coils thats why i was wondering, but i've seen the internal after market performance coils from autozone/pepboys, but once again i was wondering if its even worthit?
Hi,
Kindly advise what do u mean when u are saying making some serious power? If I am planning to make my 4dr eg with crower stage 3 cam (NA), do I need to upgrade my ignition coil or not?
Stay away from MSD. nuf said, you don't need it. If your motor is making over 800hp and running on ethanol, then go buy that little red box and bolt it to your fire wall. if your making over 800whp and i see a MSD box i will not laugh, I promise
siavosh
28
Mar 30, 2010 12:08 AM
