Do ITR calipers come with the 25t or the 23t brackets?
I just ordered a set of calipers from checkers and the caliper itself is correct but what bothers me is the 25t bracket they came with. I thought ITR's came with 23t's?
dang...i specifically ordered 97 itr semi-loaded calipers. the caliper is correct though. I'm wondering if all the itr calipers that beck arnley reman come with 25t brackets?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote"> ordered a set of calipers from checkers</TD></TR></TABLE>
that was your first mistake. checkers, partsusa, kragen. the company cant even decide on one name for their stores.
not that you would do this but if somebody else needed just the brackets a company called Dorman makes them and the part number for the front 23t bracket is 619-306
maybe return them and order the legend gs dual piston calipers w/28t brackets, mill a few mm from the backs of them (brackets), and get some 28mm rotors drilled with your lug pattern from Brain Hasty @ FastBrakes. it's a heavier setup than the others, but it fits under many 15" wheels and affords superior heat handling.
My USDM 98+ ITR front knucle/hub/rotor/caliper assembly came with 25T. It was all assembled like that. It was pulled from a 5-lug ITR at an auto recycler.
Hope that answers your question. I found some other honda-tech articles confirming this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">not that you would do this but if somebody else needed just the brackets a company called Dorman makes them and the part number for the front 23t bracket is 619-306
Awesome info
Any idea if they make brackets for the rear calipers? I want some pizza pans on the back of my EG as well
</TD></TR></TABLE>Awesome info
jfoster
Suspension & Brakes
Mar 29, 2009 07:58 PM
sumyungguy
33
Mar 30, 2006 06:59 PM
SilverDc2
Jun 4, 2003 07:46 AM
