axle seal
Old Apr 6, 2007 | 01:03 PM
ED9man's Avatar
Default axle seal
went to install a new axle seal on the driver side of my 92 GS-R transmission because the old one blew out and dumped all the fluid out very quickly. Well I take the int shaft out, put the new seal in, I used a screwdriver to gently push it in a little bit pushing a little on each side until it was even and I cleaned the area with some brake cleaner. Well I put everything back together and the car is dripping fluid out the seal. WTF?! Did I do something wrong, how are you supposed to install the seal? It felt like it pushed in all the way. This really sucks. Any suggestions?
Old Apr 6, 2007 | 03:26 PM
Crazydave's Avatar
Default Re: axle seal (ED9man)
use a seal driver, and make sure it goes in all the way.
or a big socket
Old Apr 7, 2007 | 10:35 AM
arc_55's Avatar
use a hammer and gently tap arond the seal continously until you think it has seated.
Old Apr 7, 2007 | 12:09 PM
nitrofish420's Avatar
I've damaged a few new seals before during installation, but also make sure you've got the correct seal. When I put a new clutch in my GSR I replaced the axle seals while it was out, and it turned out the driver's side seal was incorrect, the inside diameter was slightly larger than the axle seal surface, and it leaked like a *****. Replace it again, making sure it fits correctly on the axle, and drive it in with either a seal driver or a properly sized socket or piece of pipe or whatnot.
Emeraldbomber
10
Feb 22, 2019 07:38 AM
inh
May 21, 2008 04:30 PM
ED9man
Apr 24, 2007 08:10 PM
See Are X
Oct 21, 2003 09:23 PM
Evil DOHC
Jun 17, 2003 05:21 AM
