Uneven suspension
Old Apr 6, 2007 | 11:10 AM
skull21's Avatar
Default Uneven suspension
I've installed Tein lowering springs. The front driver's side is higher than the rest. I have swapped the driver's side and passengers side and still have the same problem of the driver's side being higher. I've checked all the mounts, compared the springs, and still have no clue why the driver's side is still higher. Is there something I'm missing that somebody can help me with and is there another way to adjust ride height on the standard car? It is a '99 Honda Civic EK
Old Apr 6, 2007 | 11:12 AM
7808's Avatar
your bushings might be twisted on that side or bent control arm could be all kinds of things, strut half blown on that side etc im no expert
Old Apr 6, 2007 | 11:45 AM
PianoMan's Avatar
Default Re: Uneven suspension (skull21)
Well, you've ruled out the springs with the swap. How much is the difference? Are we talking a few millimeters, or inches?
PM
Old Apr 6, 2007 | 01:59 PM
skull21's Avatar
Default Re: Uneven suspension (PianoMan)
The difference is 15 / 17 millimeteres (a significant visual and handling difference).
Old Apr 6, 2007 | 02:20 PM
mikealicious's Avatar
polyeurthane bushings my friend. will fix everything and give you better handling.
Old Apr 6, 2007 | 02:34 PM
sicones's Avatar
where did you buy the springs, their selling boot leg springs on e-bay, and are the springs properly seated in the strut??
Old Apr 6, 2007 | 02:46 PM
ekb16's Avatar
i have the same problem...i have KYB shocks with H&R springs all around and my LF is lower than my RF...i came to find out that my RR upper shock mount bushing wasnt on right when the guy installed it b4 i bought the car...its still sittin the same as b4 until i get new suspension or if i can get an upper bushing from somewhere
Old Apr 6, 2007 | 03:34 PM
marquisdee1018's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem...i have KYB shocks with H&R springs all around and my LF is lower than my RF...i came to find out that my RR upper shock mount bushing wasnt on right when the guy installed it b4 i bought the car...its still sittin the same as b4 until i get new suspension or if i can get an upper bushing from somewhere</TD></TR></TABLE>
I have the same set up but my RF is lower than my LF. I'm going to replace all my bushings.
Old Apr 6, 2007 | 05:20 PM
siVix's Avatar
Default Re: (marquisdee1018)
I have that same set up too^^^ but it's my passenger rear that's an inch higher than the rest. I've taken it apart, put it back together, swapped them around, etc it's always that same damn corner. I figured it was something I wasn't seeing that was bent or tweaked or I just ended up with a goofy spring, first time I've had H+Rs.
Old Apr 6, 2007 | 05:28 PM
ekb16's Avatar
lolz...didnt noe that much ppl had this setup...and we all have the same problems but on diff. corners..
Old Apr 6, 2007 | 05:32 PM
Raw B's Avatar
Default Re: (ekb16)
When you take your suspensions apart, make sure that when you bolt things back together, you compress the suspension at each corner ( using a floor jack ). Or if possible, put the car on the ground , then tighten things up.
Old Apr 6, 2007 | 05:37 PM
2coupes's Avatar
exactly why an adjustable suspension is desirable
Old Apr 6, 2007 | 08:20 PM
myhatchsi's Avatar
New User
Default Re: (2coupes)
i have the same problem on my eg. i just learned about this place and i think is great. thanx 4 all the help.
Old Apr 6, 2007 | 10:41 PM
dftravis's Avatar
Just save up and buy fully adjustable coil overs. Well worth it in every way. I recomend omni power
Old Apr 6, 2007 | 11:17 PM
EKidd's Avatar
Default Re: (siVix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siVix &raquo;</TD></TR><TR><TD CLASS="quote">I have that same set up too^^^ but it's my passenger rear that's an inch higher than the rest. I've taken it apart, put it back together, swapped them around, etc it's always that same damn corner. I figured it was something I wasn't seeing that was bent or tweaked or I just ended up with a goofy spring, first time I've had H+Rs.</TD></TR></TABLE>
I have the same problem as you bro. I got agx's w/ h&r race springs and my rear passenger side is higher
Old Apr 7, 2007 | 12:25 AM
siVix's Avatar
Default Re: (EKidd)
So that's 4 members of the 1 taller than the rest H+R/KYB squad already? We need to start working on some stickers
Old Apr 7, 2007 | 04:25 AM
Default Re: (siVix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siVix &raquo;</TD></TR><TR><TD CLASS="quote">So that's 4 members of the 1 taller than the rest H+R/KYB squad already? We need to start working on some stickers </TD></TR></TABLE>
LOL
Old Apr 7, 2007 | 10:53 AM
skull21's Avatar
ok so i have tried every possible answer. im going to replace all the bushes and see what happens. thanks for the help guys.
oh and if the bushes dont work ill start designing stickers
prostreetonline
Dec 5, 2005 03:51 PM
92inprogress
May 19, 2005 08:41 AM
mist sITR
Apr 19, 2004 10:26 AM
Tofurky
Oct 7, 2002 04:42 PM
badnan
Jun 5, 2002 01:29 PM
