Updgrade Brakes For Type R Engine???????
Old May 26, 2002 | 08:38 PM
94Si's Avatar
Default Updgrade Brakes For Type R Engine???????
Im gonna be putting a type R engine in soon. but im i wanna upgrade my brake system.what would be the cheapest way to do it. I was looking into 5 lug conversion/type R suspension for the looks/brake performance. People told me just to do a big brake conversion. im gonna be putting some tein full coilovers on soon,but i gotta know what i should do so i can get the coilovers for my car,or type r suspension. i got some brembo cross drilled/slotted i can put on but i dont know if that will be enough power to stop.Do i need bigger rims for the big brake. HELP ME OUT!.
[Modified by 94Si, 5:40 AM 5/27/2002]
Old May 27, 2002 | 10:59 AM
94Si's Avatar
Default Re: Updgrade Brakes For Type R Engine??????? (94Si)
ANYONE?!?!. getting a type r swap. if you got any swap should i upgrade?
Old May 27, 2002 | 01:33 PM
hybridcivic93cx's Avatar
I have a 98 GSR front suspension: control arms, spindle, calipers, new rotors and pads for my hybrid. I havent done it yet because I am still waiting for my mail ordered braided brake lines. I am not planning on swaping tht rear drums though. Most of the braking on a front drive car is the fronts. As of now, the 9 inch stock rotors do an ok job.
Old May 27, 2002 | 01:36 PM
fowler!'s Avatar
Default Re: Updgrade Brakes For Type R Engine??????? (hybridcivic93cx)
Do a gsr brake upgrade. That would be the most economical thing to do.
Later on down the line, upgrade to a fastbrakes kit..they have some mighty good stuff
Old May 27, 2002 | 01:45 PM
Default Re: Updgrade Brakes For Type R Engine??????? (fowler)
The stock discs are 9.1 inches while the gsr's are 10.1. Do the math and that equals a better stopping platform to work from. Your next upgrade from that could be type r calipers and redrilled discs to 4 lug. That is 11 i believe.
Old May 27, 2002 | 02:00 PM
fowler!'s Avatar
That and an ITR or GSR mc/booster. Civics suck...I've found that out recently
[Modified by fowler, 3:01 PM 5/27/2002]
Old May 27, 2002 | 02:43 PM
JV's Avatar
JV
Who?
I'd go with an RS Integra MC/ brake booster , That way you don't have to bend any lines.......
Old May 27, 2002 | 03:19 PM
spoon_ek9's Avatar
Default Re: Updgrade Brakes For Type R Engine??????? (JV)
fastbrake
it could fit in a 15" rim(stock rim might need a spacer)
[Modified by spoon_ek9, 12:20 AM 5/28/2002]
Old May 27, 2002 | 05:20 PM
94Si's Avatar
THANKS. but what should i do. whats gonna be cheaper yet work just as good. i got a set of brembo cross drilled slotted(havent used). will those and some good brake pads work good. or do i need new calipers. Also im going with the tein full coilovers and i heard you need type R LCA. if so maybe i'll just do the conversion. how much does the AEM Big Brake Conversion go for w/calipers?
Old May 27, 2002 | 05:43 PM
GokuSSJ4's Avatar
well , if you go gsr , and then plan to upgrade that would be cheaper . if you go with type R the smallest rim that youcan fit isd a 15' rim.
with teins or any japanese coil over (at least most of them ) you need type R lca , but is no big deal .
Old May 27, 2002 | 05:48 PM
Greg L's Avatar
i would say for tha front, use the Wilwood kit if u got tha $$$, and then new pads, rotors and brake lines in tha back cus its an Si right and already has rear discs.
edit: the wilwood kit might fit under sum 15" wheels
[Modified by WannaBFast, 2:49 AM 5/28/2002]
Old May 27, 2002 | 05:50 PM
Greg L's Avatar
Default Re: Updgrade Brakes For Type R Engine??????? (spoon_ek9)
fastbrake
whut rims are those, Koesi K1s???
Old May 27, 2002 | 05:58 PM
cr00klyn718's Avatar
Default Re: Updgrade Brakes For Type R Engine??????? (WannaBFast)
[QUOTE]fastbrake
how much those brakes go for?? btw nice wheels
Old May 28, 2002 | 11:32 AM
spoon_ek9's Avatar
Default Re: Updgrade Brakes For Type R Engine??????? (cr00klyn718)
i think the brake kit is around 700. and yes, its kosei K1 painted by me.
Old May 28, 2002 | 11:40 AM
Jonathan_ED3's Avatar
spoon_ek9, what size tires are those and how much do those go for?
Old May 28, 2002 | 12:02 PM
ZylexSNL's Avatar
RIP ILL: 26Jan1945-02Feb2017 -&- JLVK: 14Jun1925-13Dec2016
Community Builder
Community Influencer
Default Re: Updgrade Brakes For Type R Engine??????? (hot_EF)
just get this from fastbrakes:
(click on the pic for the link)
i've got it at home, waiting to install...
[Modified by ZylexSNL, 4:05 PM 5/28/2002]
Old May 28, 2002 | 12:07 PM
spoon_ek9's Avatar
u mean the tire and rim? size is 205/50/15, rim is 15 X 7. for tire, its pretty cheap. rim is around 500
Old May 28, 2002 | 12:19 PM
Mario's Avatar
Default suggestion...
These are nice, because unlike most other aftermarket calipers, you can use ITR sized brake pads (easy to find),
This belongs to my friend who lives in Florida. Good job Paul
Old May 28, 2002 | 01:30 PM
djay86's Avatar
Default Re: suggestion... (supersonic dc2)
ask One Point EK... he had alot of trouble with his brake swap.. he suggested just to upgrade your stock brakes. i.e. steel braided lines, new calibers, and rotors
Fink2iCe
Jul 22, 2004 09:22 AM
Spartanic
Jan 16, 2003 06:16 AM
TurboSHO
Nov 12, 2002 05:44 PM
