Electric load detector?
Old Apr 6, 2007 | 08:06 AM
its WANG yoO's Avatar
Default Electric load detector?
throwing code 17- speed sensor, 20- electric load detector, 41- primary o2 heater, 65- secondary o2.
What the hell is electric load detector? and the o2 codes...does that mean both o2's need to be replaced? Thanks in advance!
Old Apr 6, 2007 | 08:15 AM
pdiggitydogg's Avatar
check your alternator fuse under the dash...when it blows you will throw eld, vss, and o2 codes all at once
Old Apr 6, 2007 | 04:07 PM
Default Re: (pdiggitydogg)
and the speedo will not work? I have to go to the shop to check the fuse...prolly tomorrow sometime. But would that make the speedo not work?
Old Apr 6, 2007 | 04:11 PM
speedo wont work because the vss says "theres an issue"
if you have eyes and a flashlight, you can check your own fuse.........................
Old Apr 6, 2007 | 04:51 PM
spoon_ek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">check your alternator fuse under the dash...when it blows you will throw eld, vss, and o2 codes all at once</TD></TR></TABLE>
i second that
Old Apr 9, 2007 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">speedo wont work because the vss says "theres an issue"
if you have eyes and a flashlight, you can check your own fuse.........................</TD></TR></TABLE>
I have eyes and a flashlight...but the car is at my buddies shop...so I have to go there and look at what your sayin.
vrotsos991
Honda Civic (2001 - 2005)
Jan 23, 2017 12:45 PM
S2kneub
Mar 5, 2013 10:50 AM
BLUE EH3
10
Jul 5, 2005 10:44 AM
hitvtecgetloud09
Nov 12, 2004 02:42 AM
bgod
Jun 5, 2003 09:50 AM
