camshaft & crankshaft seals
I ordered both a crankshaft seal and camshaft seal from my local honda and when looking at them, the are the same seal. Even the part #'s match up. Are the crank and cam seals suppose to be the same thing?
Well I can't find a pic of this crankshaft seal, but the cam seal is #21 here:
http://www.thehondapartsstore....ch=no
Its not the same because it only came up as a cam seal
You got 2 by mistake
Thanks Man. I appreciate your help on this. So I basically got two cam seals. Hmmm.... But when I look for the crank seal, i can't find the part #. Any help here cause I can take back one of the cam seals today and get a crank seal when I got to pick up my car from the shop.
Alright this is what I think I have here.
I've got two of the crank oil seals that go on via the oil pump (91212-P2F-A01).
What I need to get is the cam oil seal which is (91213-P2F-A01).
Am I right on this guys?
One more question. I'm a little fuzzy w/ where the oil pump is but is it behind the crank wheel and in order to replace it, i would simply unbolt the crank wheel, pop out the old one and put in the new one?
NeverOut215
Sep 30, 2011 08:56 AM
