Clutch pedal wont release until.....
Old Apr 5, 2007 | 09:11 PM
94allmotor's Avatar
Default Clutch pedal wont release until.....
ok let me explain the problem i broke the flywheel and starter when i was driving in 3rd meant to shift to 4th but idk somehow it went into 2nd (dumbass) my shifter bushings are worn out thats prob. the reason why. ok so now when i go to shift if i bring it all the way to redline the clutch sticks to the floor and releases in about 2 seconds or a bit more. what could be the problem. by the way its a 00 type r lsd tranny
Old Apr 5, 2007 | 09:14 PM
SlowReaction's Avatar
Default Re: Clutch pedal wont release until..... (94allmotor)
Replace the fluid in the hydro system and check to see if theres grease on the throw-out bearing.
Old Apr 5, 2007 | 09:16 PM
94allmotor's Avatar
Default Re: Clutch pedal wont release until..... (SlowReaction)
is this the only solution? cuz i was wondering if this tranny is still useable if it is im gonna put it up for sale. btw i have a very thin piece of wood under the pedal do it wont go all the way down. thats what i been doing for a while
Old Apr 6, 2007 | 06:18 AM
94allmotor's Avatar
Old Apr 6, 2007 | 12:11 PM
FarinaMotorsports's Avatar
Default Re: (94allmotor)
It sounds like you might have some air in the system. Try bleeding it and see if that helps. If that doesn't help it could be the master or slave cylinder, but I doubt it.
Old Apr 6, 2007 | 12:33 PM
Default Re: (FarinaMotorsports)
This has nothing to do with the tranny. It has something to do with the clutch system The tranny will not cause a pedal to stick.
Old Apr 6, 2007 | 01:20 PM
94allmotor's Avatar
replaced both slave and master cylinder replaced pressue plate and clutch and tried on diff. motor and it still does the same thing
Old Apr 6, 2007 | 02:38 PM
NathanielH's Avatar
you tried what on a different motor? It sounds like a hydraulic issiue, or like there is some sort of mechanical failure with the clutch pedal or throw out bearing...
Old Apr 6, 2007 | 04:03 PM
Default Re: (NathanielH)
Have you check the clutch pedal? is there grease? Is it to tight? is it bent?
Old Apr 7, 2007 | 06:52 PM
94allmotor's Avatar
Default Re: (SlowReaction)
only thing i didnt change is the throw out bearing i got new clutch and new pressure plate and it still sticks i changed both master and slave cyl.
Old Apr 9, 2007 | 01:01 PM
NathanielH's Avatar
get a new bleeder. make sure you are bleeding it properly (pump the clutch pedal til some pressure builds up. have a buddy open the bleder screw on the slave cylinder, and shut it before fluid stops coming out. do that a bunch of times, till there are no bubbles, and the fluid is nice and clean. remember to add fluid as the level drops in the master, see if that helps.
Old Apr 10, 2007 | 08:10 PM
94allmotor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">get a new bleeder. make sure you are bleeding it properly (pump the clutch pedal til some pressure builds up. have a buddy open the bleder screw on the slave cylinder, and shut it before fluid stops coming out. do that a bunch of times, till there are no bubbles, and the fluid is nice and clean. remember to add fluid as the level drops in the master, see if that helps. </TD></TR></TABLE>
did that a thousand times
Old Apr 10, 2007 | 08:59 PM
arc_55's Avatar
I would check your clutch fork for any damage as it might be binding if there has any damage to it. Also quick question.... did you bench bleed the master? did you accidently bottom out the piston when doing so?
Old Apr 11, 2007 | 07:10 AM
NathanielH's Avatar
Well if you bleed it a thousand times, and have a new slave and master cylinder, it is not a hydraulic issiue. start inspecting the through out bearing, fork, pressure plate, ect.. for somthing that is mechanically binding.
Old Apr 16, 2007 | 06:26 AM
NathanielH's Avatar
so did you figure it out?
thierry
Feb 26, 2010 12:33 PM
luder916
Jul 30, 2008 11:11 PM
tegsallgood
Honda S2000
12
May 23, 2007 06:40 AM
phyzJunkieCivic
May 3, 2007 10:52 AM
MadCityLude
Aug 25, 2006 05:12 AM
