vtec and turbo? does it work well, me and friend are having a discussion
Old May 26, 2002 | 07:02 PM
Andrea_Aunie's Avatar
New User
From: work in Tennessee and live in Georgia, from Tampa, Florida, USA
Default vtec and turbo? does it work well, me and friend are having a discussion
are turbos better /easier with nonvtec or vtec engines, when i told my friend that a nonvtec engine worked well with turbos cus of the low compression and longering gearing and that i didnt really care about vtec, he basicly started this topic... i mean, i know u can have a turbo and run vtec, im just confused on how much harder wold it be to maintain one on a vtec engine
this is what he tells me
actually Aunie, you are 100% wrong...vtec is perfectly fine to run with turbo's when you hear people talking bad about it, is because of the lag....well that is because it is people that are used to having vtec in the first place, those people without it never knew what it felt like in the first place...Having vtec inabled just gives you that much more power then boost finally hits. And as for the valves staying open...that is the whole reason why companies like Crower and Skunk2 create turbo cams for cars with vtec....it's harder to tune a car that still has vtec inabled, so most people don't mess with it, but the advantages of having it still are hugely there if you have someone who knows what the heck they are doing.
Old May 26, 2002 | 08:36 PM
threatcon13's Avatar
New User
Default Re: vtec and turbo? does it work well, me and friend are having a discussion (Andrea_Aunie)
actually aunie, your friend was right about the first part, he just forgot to mention that both nonvtec and vtec motors will have that lag because vtec doesnt kick in until after the turbo spools also the second part, I didnt notice the abundance of aftermarket "turbo" cams. most people on here are running stock cams just fine in upwards of 15 lbs of boost. and to answer your question, LS turbo vs. GSR turbo, the differences are minimal once the boost is increased...easier, that doesnt even apply.
Old May 27, 2002 | 07:32 AM
Chubz's Avatar
Default Re: vtec and turbo? does it work well, me and friend are having a discussion (ALLMOTORDC2)
but have u ever seen a dyno from a turbo VTEC equipped car (big turbos), at cross over there is like a 75-100+ hp jump
Old May 27, 2002 | 08:01 AM
Hapa DC5's Avatar
Default Re: vtec and turbo? does it work well, me and friend are having a discussion (SuperTech)
aren't most full drag turbo vtec cars have the vtec disconnected... aem civic for instance...?
Old May 27, 2002 | 12:06 PM
mr dusty2's Avatar
Default Re: vtec and turbo? does it work well, me and friend are having a discussion (NemesisGSR)
they have vtec disconnected because they dont really need seperate cam lobes for high and low rpms...they only idle for about 5 secs, right?....please tell me if i'm wrong
Old May 27, 2002 | 12:24 PM
SIK IN DA HED's Avatar
New User
Default Re: vtec and turbo? does it work well, me and friend are having a discussion (mr dusty2)
this is going to be a flame war sooner or later.
Old May 27, 2002 | 12:28 PM
mr dusty2's Avatar
Default Re: vtec and turbo? does it work well, me and friend are having a discussion (dlplayboy)
i hope i didnt contribute to it
Old May 27, 2002 | 12:39 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
The fact that your friend thinks vtec kicks in before the turbo shows that hes a dumb ***.. no offense.
[Modified by GSR-OwnzJo0, 9:39 PM 5/27/2002]
WaynePlayer
Oct 26, 2017 06:37 AM
bad_asz_mushak
Dec 14, 2003 09:38 PM
Slvr_CRX
Aug 25, 2003 02:56 PM
Andrea_Aunie
May 26, 2002 08:17 PM
hondanacura4life
May 19, 2002 07:58 PM
