huge temp problem !!!!!! please help!!!!!
Old Apr 4, 2007 | 11:25 PM
11secteg's Avatar
Default huge temp problem !!!!!! please help!!!!!
ok i was having some issues with my car over heating so i bought a new thermostat new dual core aluminum radiator ...two slim fans (pusher and puller ) heat rapd the downpipe ....
i filled it up with water wetter (**** i allways use )
let it run kept topping off the water ...
let it run for about an 30min .. and i look at the gauge and it's pasted hot...
so i turn it off .. feel the radiator and the hoses ...their still cold from puring the water in ... i felt the top of the radiator still cold ...
took the cap off ...still nothing ...
iam confused ... the only thing i can think of is get a new temp sensor...ive alredy replaced everything else ...
any imput would be awsome ...
Old Apr 4, 2007 | 11:47 PM
11secteg's Avatar
Default Re: huge temp problem !!!!!! please help!!!!! (11secteg)
will someone give me any idea whats wrong ...
Old Apr 5, 2007 | 04:24 AM
hondamanwill's Avatar
After running that long did the fan come on?
Old Apr 5, 2007 | 12:32 PM
firetech's Avatar
Might sound like a stupid question but was the thermostat installed facing the correct direction. If it was not installed properly it will not open.
Old Apr 5, 2007 | 01:49 PM
11secteg's Avatar
Default Re: (hondamanwill)
i have them wired to the ignition ..
11secteg's Avatar
Default Re: huge temp problem !!!!!! please help!!!!! (firetech)
i think it will only go in one way correct?
Old Apr 5, 2007 | 03:27 PM
base-op.1320's Avatar
Check your water pump also
Old Apr 6, 2007 | 01:04 PM
deftonerider's Avatar
make sure the system is bled of air, air in the motor will make it overheat even thought the rad hoses and cap ar COLD
Old Apr 6, 2007 | 03:17 PM
Crazydave's Avatar
Default Re: (deftonerider)
Things you need to check.
does you fan turn on and then turn off
Do both hoses get hot
Have you pressure tested your system
If both hoses are not getting hot, it's likely your thermostat (you have to make sure that you got the right one for your car, that it's installed correctly and if it's offset, that you have it clocked correctly.
Old Apr 6, 2007 | 06:13 PM
arc_55's Avatar
i would do what everyone has mentioned above! I would like to add one more thing... Back probe your coolant temperature sensor with a multimeter and start your car up. Give your car a few mins to "warm" up and watch the reading on the multimeter in relation to the temp gauge. This can tell you if there is a sensor problem or soley a wiring issue.
A warmed up engine should read about .6 volts
Modified by arc_55 at 7:40 PM 4/6/2007
TooFastVTEC
11
Jul 20, 2012 11:53 AM
MFButler
Mar 11, 2010 11:30 AM
integraNooB
Mar 26, 2008 09:31 AM
DaveSi677
Jul 5, 2006 10:35 AM
drewcandraw
10
Jun 8, 2005 10:37 AM
