Please Help Custom Piston Question
Old Apr 4, 2007 | 11:15 PM
slowferio714's Avatar
Default Please Help Custom Piston Question
I'm building a stroked ls-v with custom JE pistons, its my first build with aftermarket parts and i was wondering if anyone who has used these pistons before had too much piston to cylinder wall clearance? would the piston, since its aluminum alloy, expand a bit during the break-in period? or should the piston fit snug like oem pistons from the get go? right now the piston to cylinder wall clearance is no where near .0025-.0035" as the instructions on JE's website states. The clearance as of now measures .035". Any information will help, Thanks in Advance.
Old Apr 5, 2007 | 06:42 AM
pomansouth01's Avatar
Ginger Kid
send those pistons back and get a set that will fit a little snugger
Old Apr 5, 2007 | 06:49 AM
Furyof4's Avatar
Default Re: (pomansouth01)
Forged pistons expand more so require more clearance.
0.0035" sounds about right to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">send those pistons back and get a set that will fit a little snugger</TD></TR></TABLE>
Edited: for decimal place.
Modified by Furyof4 at 12:59 PM 4/5/2007
Old Apr 5, 2007 | 08:56 AM
DonF's Avatar
Default Re: (Furyof4)
you forgot a "zero". 0.0035 sounds about right, or what ever CP says it should be.
Old Apr 5, 2007 | 08:59 AM
Furyof4's Avatar
Default Re: (DonF)
Woops, your right.
Changed it.
Old Apr 5, 2007 | 02:33 PM
Ginger Kid
haha hopefully slowferio forgot a zero too.
Old Apr 5, 2007 | 04:08 PM
Combustion Contraption's Avatar
Hopefully. CP recomends .0035 for turbo apps, .003 for NA. Its designed into the skirt. If they sell you an NA style forging thats marketed for an 4" bore, the piston will measure 3.997 in the area you would measure for p2w.
Old Apr 5, 2007 | 04:12 PM
Suck my DX's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully. CP recomends .0035 for turbo apps, .003 for NA. Its designed into the skirt. If they sell you an NA style forging thats marketed for an 4" bore, the piston will measure 3.997 in the area you would measure for p2w.</TD></TR></TABLE>
do allpiston manufacturers follow this practice?
Old Apr 5, 2007 | 05:00 PM
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
do allpiston manufacturers follow this practice?</TD></TR></TABLE>
Most, but some are more accurate than others. This is why you should bring your pistons to your machinist when getting your final hone on your block. So he can take indiv. measurements on each piston and size each bore accorindingly.
Old Apr 5, 2007 | 05:22 PM
Suck my DX's Avatar
Most, but some are more accurate than others. This is why you should bring your pistons to your machinist when getting your final hone on your block. So he can take indiv. measurements on each piston and size each bore accorindingly.</TD></TR></TABLE>
that makes sense....thanks
Old Apr 5, 2007 | 06:26 PM
yeah mine measured .035, no missing "0" here.. so i should really send the pistons back?
Old Apr 5, 2007 | 08:39 PM
Absolutely. Thats a ridiculous amount of clearance.
Old Apr 5, 2007 | 09:28 PM
:Josh:'s Avatar
Default Re: (slowferio714)
How are you measuring piston to wall clearance? The piston will measure quite a bit smaller at the top.
Old Apr 6, 2007 | 05:50 PM
the measurement i took was from the top.. i'm not sure how to measure this. would the piston expand .01''
Old Apr 6, 2007 | 06:41 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowferio714 &raquo;</TD></TR><TR><TD CLASS="quote">the measurement i took was from the top.. i'm not sure how to measure this. would the piston expand .01''</TD></TR></TABLE>
i dont know either, but i would assume to take the measurment from the bottom of the bore, because the circumference of the piston skirt is larger than the circumference of the top area where the rings are ... i hope an experienced builder can verify
Old Apr 6, 2007 | 07:59 PM
Each manufacterer reco's a diff. place to mic the skirt. Usually an inch or two from the bottom. You would get extreme excessive clearance if you measured at the top.
Old Apr 6, 2007 | 09:16 PM
Thanks guys! i'll have to post up my dyno when i'm done!
Old Apr 8, 2007 | 06:02 AM
Ginger Kid
so I guess they fit!!
Txdragon
Engine Machining & Assembly
27
Nov 9, 2018 05:52 PM
h22_crx
May 4, 2006 04:57 AM
dude_123
Sep 29, 2005 08:02 AM
95c1v1cs1
Jul 28, 2004 09:44 AM
