car sitin side ways
i got a pretty aggressively dropped 97 ek hatch and i had it drop for a while now. my passanger side (more the front then rear) of the car is lower then drivers side and im wondering y this is? few of my opinions r: i need an alignment (cuzz i never had one), need a camber kit, need new shocks (but the ride is not bumpy) or the place i got my car dropped might have juss put the left lower then the right by mistake. on yea just to let ya kno, i got cut tein springs on the backs and coilovers on the fronts. so id like to kno ur opinions. thanks.
Whoa whoa whoa back the trolley up there buddy.
First of all, you didn't get an alignment after a drop.
Second, you CUT springs and put them on?
Third, you have regular springs (not to mention cut) on the back and coilovers on the front?
Were you desparate about a drop and short on money or something dude? That is the most ghetto suspension I've ever read of so far. Try seeing if the front right coilover is adjusted lower than the driver front. Could be a high possibility. But damn dude, get that setup straightened out lol.
My opinion? get some non-ghettoed out suspension.
Get a decent shock and some H&R's or eibachs.
Don't go cheap on you're suspension man. You're leading yourself into Thousands of dollars in damage to suspension/brake/wheel/tires just by rising on a **** drop without an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">My opinion? get some non-ghettoed out suspension.
Don't go cheap on you're suspension man. You're leading yourself into Thousands of dollars in damage to suspension/brake/wheel/tires just by rising on a **** drop without an alignment.</TD></TR></TABLE>
x2...not good to blow ur **** to pieces cuz u want it lowered/to save a dollar
I have the same problem, the whole passenger side is lower than the drivers side... I have neuspeed springs and tokico shocks. But I didnt get an alignment. So is that the problem?
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">I have the same problem, the whole passenger side is lower than the drivers side... I have neuspeed springs and tokico shocks. But I didnt get an alignment. So is that the problem?</TD></TR></TABLE>
Alignment won't fix ride height. You installed something wrong.
Bump stops maybe?
Bump stops maybe?
hahah i kno it sounds ghetto but i really waznt tryna do that i did the whole tein springs n it didnt drop to where i wanted to....even the dude at the shop waz suprised that it didnt drop that much, so i had them cut them (since theyre recutable). the bacc ones were fine, but the front ones were cut TOOOOOO low. so i bought sum coilovers and rasied the front a bit and left the baccs on.
heard that was normal becuase the driver side is heavier than the passenger, the motor is substantially heavier than the transmisson,
why did you expletive up tein springs? are they teins or are they ebay "teins"
dont cut springs, go get some kyb adustables and go get some springs again, do the washer trick and go get an alighnment
knock out everything at once
if the driver side is heavier, wouldnt the driver side be lower then the passanger? mines the other way around. and they're real teins, ordered them from a local shop. they just didnt drop to where i wanted them to and they are recutable...so i did it. the ride is fine, not bumpy or hard at all. just passanger side is lower then the drives side.
Cut springs or cheap springs with too agressive of a drop will blow out even good shocks in a hurry. Dont cheap out with ebay coil-overs cuz they will do the same thing. IMO if you want a decent ride with a drop, go with eibach sportlines and konis. Looks good, and rides firm but nice. If you want all out performance, go with a reputable coil-over, but be prepared to spend $. And always, ALWAYS get an alignment any time you even mess with your suspension. Camber kits are a good investment.
i dont have a budget. ill buy whatever, no matter the cost....if i want it, ill get it. but i just dont wanna go all CRAZY RACE OUT stuff. just want basic but good suspension for everyday uses and for the tracks. i was thinking about tein basic damper. but iono what do u guys think? keep in mind that i still wanna keep my car SLAMED.
You need an agressive shock paired with Ground control coilovers or H&R race springs/neuspeed race springs.
I recommend Tokico illuminas and Koni yellows.
some links of good products would be helpful, please. cause not really sure what im looking for on ground control coilover. what i found look excatly like the cheap coilovers i have on right now.
crxzc
Feb 19, 2002 09:38 AM
