JDM cluster not reading
i recently finally got my motor running. first start up the cluster was fine. lights needles and everything was working. now the needles dont move at all and some of the warning lights dont light up like on first fire. but the gauges do light up and the fuse is not blown. anyone had something similar happen or might be able to give me direction as to what it might be? im at a complete lost. thanks
i havent driven the car yet......waiting to get a rough tune, so not sure about the odometer....ill get on the vss this weekend. i was too tired to start troubleshooting tonight (havent been to sleep in over 24hrs)
thanks for the suggestion
sometimes jdm clusters don't work cause they were damaged when shipped here. i seen about 8 that didnt work and just simply needed to be replaced
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">sometimes jdm clusters don't work cause they were damaged when shipped here. i seen about 8 that didnt work and just simply needed to be replaced</TD></TR></TABLE>
that would be the worse case scenario....and if thats the way it is hopefully you overpaid and bought from an actual shop so you can send it back.
mine went crazy when my VSS sensor went on the fritz...so hopefully yours is your vss
on the back of the cluster, those solder points, are they suppose to be soldering down the ribbon to the back of the cluster? theres like 10 of them and 8 of them are lifted off the cluster housing with the ribbon.... hopefully that made sense.
the cluster i personally brought back from japan a few years ago. got it in a junkyard for a couple bucks. like i said before, it worked for about the first 5min that the engine was idling and after i adjusted the fuel psi then looked back in at the RPMs it was dead but still had idiot lights
with the VSS. im not getting continuity between the sensor and ecu with the orange wire. all the contact points seem to be clean, no corrosion. so im gonna try to swap out the sensor pickup thats bolted to the VSS.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_eg »</TD></TR><TR><TD CLASS="quote">on the back of the cluster, those solder points, are they suppose to be soldering down the ribbon to the back of the cluster? theres like 10 of them and 8 of them are lifted off the cluster housing with the ribbon.... hopefully that made sense.
the cluster i personally brought back from japan a few years ago. got it in a junkyard for a couple bucks. like i said before, it worked for about the first 5min that the engine was idling and after i adjusted the fuel psi then looked back in at the RPMs it was dead but still had idiot lights.</TD></TR></TABLE>
lluks_844
Jun 1, 2007 05:01 PM
MrSmith
12
May 25, 2002 01:13 PM
