my car won't even move.....
Old Apr 4, 2007 | 06:54 PM
s0n!c's Ls inTeG's Avatar
Default tranny trouble.....help please....
i don't know what happened. my car was working fine earlier today and my dad moved it and it worked just fine. then i get in the car to go get some smokes and the car won't engage into gear. i have a 91 integra with a cable tranny. is there some way to adjust the tranny? or is it that my cutch is gone???.....any help with this would be greatly appreciated.....thanks
Old Apr 4, 2007 | 07:43 PM
dtapia's Avatar
Default Re: tranny trouble.....help please.... (s0n!c's Ls inTeG)
sounds like a clutch went
Old Apr 4, 2007 | 07:48 PM
hondamanwill's Avatar
try loosing the cable and see if it will engage.
Old Apr 17, 2007 | 07:14 PM
Default Re: tranny trouble.....help please.... (hondamanwill)
ok i checked my tranny and i think i broke the pressure plate because the car will engage into gear when the car is off. but whenb i turn the car on it won't go into any gear unless i force it into reverse. and even when i do that it grinds and then it feels like the tranny drops. then it's in reverse. so frankly i don't know what to do. do i just replace the clutch and pressure plate or should i just get a new tranny? any advice with this will be greatly appreciated.
Old Apr 17, 2007 | 07:18 PM
93supercoupe's Avatar
dont put the tranny in geare ANYMORE!!
Buy a clutch setup (consistring of a presure palte and clutch disc)
Ur tranny will need an oil change
Old Apr 21, 2007 | 08:17 PM
Default Re: tranny trouble.....help please.... (93supercoupe)
ok so i bought a jdm xtd stage 3 clutch kit. i'm just waiting for it to arrive. i'll be putting it in within the next week. my friend said that it might still be the tranny tho. so should i start looking for a tranny now or should i just wait til i put in the clutch?
Old Apr 21, 2007 | 09:07 PM
dtapia's Avatar
wait until you take the transmission out i bet the clutch disk is completly gone or the dampner springs are flopping in the pressure plate.
Old Apr 22, 2007 | 11:44 AM
00Red_SiR's Avatar
All Motor Mentor
It's your clutch. If it was your transmission it wouldn't matter if your car was running or not, it would not affect the way it shifts. If you can only shift it into gear when the car is off, it means the clutch is faulty.
Old Apr 29, 2007 | 06:22 PM
Default Re: tranny trouble.....help please.... (00Red_SiR)
yes it was the clutch. thank god. so now it's running fine except i gotta push start everywhere cause my starter is cracked. quick question tho. will the zc tranny fit the Ls??
Old Apr 29, 2007 | 06:26 PM
no, u needa B series tranny.
just get another LS trans.
Old Apr 29, 2007 | 07:05 PM
no it's not fer me. a friend asked me the question and i didn't know cause i heard some b series parts and zc parts are interchangable. i just didn't know which ones.
Spody02
Apr 21, 2008 09:36 PM
JDMified
Nov 2, 2005 03:53 AM
Loaded Butane
16
Aug 20, 2003 02:31 PM
NewIntegraKid
Mar 25, 2003 10:35 AM
BoostedED9
Nov 13, 2002 05:47 AM
