Suspension & Brakes Theory, alignment, spring rates....
Confused over alignment report
Old Apr 4, 2007 | 03:34 PM
jmai86's Avatar
Default Confused over alignment report
So I just got an alignment after dropping my 4th gen prelude about 2". Alignment was very cheap (Local shop) so I wasn't expecting much.
Here are the results:
FRONT RIGHT
Camber: -1.9 deg
Toe: 1/16in
Toe before: 0in
FRONT LEFT
Camber: -1.9 deg
Toe: 0in
Toe before: -1/16in
REAR RIGHT
Camber: -2 deg
Toe: 1/8in
Toe before: 1/8in
REAR LEFT
Camber: -2 deg
Toe: 1.8in
Toe before: 1/16in
My question is WHY was toe changed from 0 to 1/16 for FR and from 1/16 to 1/8 for RL?
Old Apr 4, 2007 | 04:33 PM
Tyson's Avatar
Default Re: Confused over alignment report (jmai86)
to get the front wheels pointed in the same direction as the rears.
does a prelude seriously require 1/4 total rear toe in?? seems like a lot.
Old Apr 4, 2007 | 04:51 PM
jmai86's Avatar
Default Re: Confused over alignment report (Tyson)
I just became more confused lol.
Guess I need to school myself some more.
I figured 0 was best in any case?
EDIT - OHH is it because the rear wheel base is wider than the front wheel base? *shrug* just a guess.
Old Apr 4, 2007 | 04:52 PM
Tyson's Avatar
well not all cases is 0 toe even the factory setting.
but i am curious what the factory specs are for your vehicle.
Old Apr 4, 2007 | 04:55 PM
jmai86's Avatar
According to the report, the specified range for toe is:
Front: -1/16 to 1/16
Total Front: -1/16 to 1/16
Rear: 0 to 1/16
Total Rear: 0 to 3/16
Old Apr 4, 2007 | 04:58 PM
Tyson's Avatar
well the total rear toe is 1/4 according to your report.
which is not within spec. and is what i am wondering about.
looks like it should be 1/8 total.
Old Apr 4, 2007 | 10:27 PM
jmai86's Avatar
That's what I was wondering about too.. would've asked but it was an asian shop and they didn't speak very good english. Did hear the shop had a good reputation though.
wannaBjdmca6
Suspension & Brakes
29
Jan 22, 2011 08:52 AM
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
joedaddy
Aug 15, 2005 09:04 PM
Understeer
Apr 4, 2003 06:25 PM
keys
Sep 7, 2001 11:21 AM
