Ok to use bolts from advance auto for turbo mani?
Old Apr 4, 2007 | 09:11 AM
slooogsr's Avatar
Default Ok to use bolts from advance auto for turbo mani?
Sup guys, just trying to find out if the bolts from the advance auto section would be ok to use on a turbo mani? Im not exactly sure if the grade will be ok but i figured you guys would know. These will be replacing most of the studs. thanx
Old Apr 4, 2007 | 11:06 AM
95dc2teg's Avatar
Default Re: Ok to use bolts from advance auto for turbo mani? (slooogsr)
ya thats where i got mine, like the variety pack. they are fine so far, no problems
Old Apr 4, 2007 | 11:11 AM
esedulerp5tenin's Avatar
my turbo/manifold bolts are M10's from sears hardware and they seem beefy as hell, so i think you should be fine
Old Apr 4, 2007 | 02:35 PM
nihad's Avatar
ok If i was you guys i would get the grade A bolts they are bronze color and i would change the bolts every other time you take the turbo off. they do break and turbo falls off.
Old Apr 6, 2007 | 06:11 AM
95dc2teg's Avatar
Default Re: (nihad)
after how long?
Old Apr 6, 2007 | 06:23 AM
slooogsr's Avatar
Sorry guys i didnt phrase my question good enough. These are the bolts that hold the manifold to the head, i replaced many of the studs in favor of these bolts. Just making sure they would be ok to use.
Old Apr 6, 2007 | 06:24 AM
slooogsr's Avatar
Default Re: (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">ok If i was you guys i would get the grade A bolts they are bronze color and i would change the bolts every other time you take the turbo off. they do break and turbo falls off.</TD></TR></TABLE>
Good idea, i may go find some of these just in case.
Old Apr 6, 2007 | 06:58 AM
CivicVX94's Avatar
Default Re: (slooogsr)
ya i bought the autozone/pep boys bolts and since have snapped off 2 bolts from my dp (yes I have a flex pipe) and both bolts off the dump tube (still one threaded into my tial). Never again......never again.
Does ARP or any other company worth a **** sell strong *** bolts online? Or do i have to vband everything lol
Old Apr 6, 2007 | 08:14 AM
HiProfile's Avatar
Default Re: Ok to use bolts from advance auto for turbo mani? (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">my turbo/manifold bolts are M10's from sears hardware and they seem beefy as hell, so i think you should be fine </TD></TR></TABLE>
I've seen some 'beefy' SSauto turbos crack. Not all metals are created equal... One thing to note is that if you overtorque any fastener, it can fail. I've used castle nuts w/SS wire as the cotter pin (through-hole) and SS sheet folded up around bolt heads/nuts (studs or blind holes) to keep things from moving, both work great and you don't have to crank on them.
You can get Grade 8 (SAE) bolts at a hardware store like Ace, or go to a real fastener place like Fastenal and get basicly anything you want, including Grade 10.8 metric. Mcmaster.com and places like boltdepot.com sell good **** online.
Your turbo/manifold connection isn't subjected to the same forces your head/block and rodend mating surfaces are, so you don't exactly need ARP for the job/
Old Apr 6, 2007 | 09:45 AM
RCautoworks's Avatar
Default Re: (CivicVX94)
Go with at least grade 8, they might hold but when your trying to take them out, most of the time they will crack.
Old Apr 6, 2007 | 10:46 AM
blaze the chemi's Avatar
Default Re: (RCautoworks)
I went to NAPA to get my self locking nuts because I changed to studs on my exhaust side. The have been great. I'm actually attempting to take them off now and they are a PITA to get to.
zexifiedlude
Nov 27, 2005 07:48 PM
Boostage
Jan 25, 2004 06:48 AM
_Endless_
Jun 9, 2003 06:58 AM
Full-Race Geoff
Sep 24, 2002 12:36 AM
austrian type-R
Apr 19, 2002 07:56 AM
