Head Milling ?????
Old Apr 4, 2007 | 07:50 AM
RaceCarRyne's Avatar
Default Head Milling ?????
if i mill my head .020 how much will htat retard the cam in degrees? is there any way to find out? maybe a formula..
Old Apr 4, 2007 | 08:50 AM
spun Vtec's Avatar
Default Re: Head Milling ????? (DC2jdmIntegra)
https://honda-tech.com/zerothread?id=1883019
page3:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">Yeah.
The cam gear is 100mm in dia. The circumfrence is ~314mm (100mm x PI). So 1mm is about 1.1 cam gear degree (2 crank degrees).
Meaning when the head is milled 1mm (creating 1mm of t-belt slack) the cam gears need to rotate 1.1 degrees to take up the 1mm slack.
with that said .55 degrees will put you back to stock. I assume you have a b series.
Old Apr 4, 2007 | 10:41 AM
Default Re: Head Milling ????? (spun Vtec)
no its an h-series
Old Apr 4, 2007 | 03:36 PM
Lubo_25's Avatar
dont mill your head...
Old Apr 4, 2007 | 08:49 PM
spun Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2jdmIntegra &raquo;</TD></TR><TR><TD CLASS="quote">no its an h-series</TD></TR></TABLE>
Way to specify expletive stick.
Ignore my first post.
Dasfinc
Jan 3, 2008 02:32 PM
Griffin@Camtech
Oct 6, 2005 07:08 PM
hanseljohn
21
Sep 11, 2005 10:13 AM
sik_sol
Apr 2, 2005 12:52 PM
jetpilot
Apr 26, 2004 09:34 PM
