Spoon / Jun3 cam / toda B in b16a block?
Old Apr 3, 2007 | 11:39 PM
Spoonson's Avatar
Default Spoon / Jun3 cam / toda B in b16a block?
Hi all, I need some help here to build up my b16a.
First of all, following is my engine set up:
- ctr piston in b16a stock block
- ctr valvetrain, injector, intake manifold.
Other modification on my car:
- ARC intake box
- mugen 4-1 header
- spoon n1 catback
- spoon throttle body
- oem ecu > will get a programmable ecu.
Due to different constrain in my area, i must stick with b16a block. (No b16b for now, i want to see how much b16a first and i have tight budget) May I have some advice for the above 3 types of cam? And i'm open for any criticize on my set up too.
I want to build my engine able to rev up to 9000-9100rpm, and looking for around 180+whp. More concerning on endurance than performance.
Spoon, i know this cam is not powerful at all, but it is closet to stock, and i can stick with the oem R's valvetrain, so I wonder according to my set up, is it possible to build up to 180whp after ecu tuning? For Jun 3 or toda B, they can do alot better, but I wonder if itr spring are compatible.
Appreciate for your comments!
Modified by Spoonson at 1:06 AM 4/4/2007
Old Apr 4, 2007 | 12:26 AM
zap's Avatar
zap
check my build thread. 180whp(dynojet) b16a with CTR pistons and JUN3 camshafts
https://honda-tech.com/zerothread?id=1756316
We tuned my car via CROME EMS. Its better to get a better valvespring like TODA or JUN if you are going for JUN 3 or TODA B.
I noticed your from Kowloon, what part? Im at HK 2-3 times a year for shopping I always go to top racing and GP Shop for my parts.
Old Apr 4, 2007 | 06:16 AM
Spoonson's Avatar
Some ppl & shops telling me the jun 3 cam will broke easily, did anyone heard about that? Is it cause by mis-installation or what?
Damn... 180whp is exactly what i'm looking for. Seems like we have similar mods; how much do you think i can get if i go for spoon cam or toda B cam? Is toda B and spoon has better mid range hp?
Yes, I'm from HK and living in Kowloon. Those shops you mentioned are the biggest parts dealer in HK!!
Old Apr 4, 2007 | 06:56 AM
JDM knowledge's Avatar
Default Re: (Spoonson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonson &raquo;</TD></TR><TR><TD CLASS="quote">Some ppl & shops telling me the jun 3 cam will broke easily, did anyone heard about that? Is it cause by mis-installation or what?
Yes, I'm from HK and living in Kowloon. Those shops you mentioned are the biggest parts dealer in HK!! </TD></TR></TABLE>i have never heard of a JUN3 cam breaking. I have heard of a Toda breaking unfortunately.
Old Apr 4, 2007 | 06:58 AM
realis9's Avatar
Default Re: (JDM knowledge)
jun3
Old Apr 4, 2007 | 07:12 AM
tartje's Avatar
Default Re: (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">jun3 </TD></TR></TABLE>
x2
however you WILL need uprated valvesprings
Old Apr 4, 2007 | 10:16 PM
zap's Avatar
zap
before when I was using a set of toda b on my other car, I got 172whp peak but better midrange and higher torque than my JUN3.
If your going for a set of spoon cams, Ive also used this before but I wasnt able to dyno it.
I estimate around 170-173whp(b16a CTR pistons/ITR intake manifold) with a very good tune.
Old Apr 6, 2007 | 06:40 AM
Spoonson's Avatar
Finally, I found a guy has experience with spoon cam!! Comparing this with toda B, any comments? I heard many ppl saying spoon is a NG cam, is it real?
Besides, do you mean spoon cam and toda b cam should having about same whp? Shouldn't toda b has better result?
I'm still having trouble to pick for a camshaft. After I put it on then i will tune it on dyno.
Spoonson
18
May 3, 2009 04:20 AM
Spoonson
20
Apr 19, 2008 01:55 PM
Spoonson
Nov 1, 2006 05:32 PM
ATS*Mark
21
Feb 9, 2003 08:12 AM
Dancing is Forbidden
Sep 19, 2002 10:10 AM
