car idles a little too rough. please help
when i plug in the stock map sensor that was on the firewall it ldles really really rough. and when i go to drive it, around 1-1.5 the car almost jumps and the whole front end just shakes!
but when i plug in the map sensor on the TB, the idle jumps from 1k to 2.5k over and over.
i got the car to ldle around 700 with the firewall map, but thats when it runs really rough.
any suggestions?
any suggestions?
Your map sensor on the TB is more then likely leaking cuaseing it to idle like that.
Have you reset the ECU to make sure you ain't throwing code 3 (MAP)?
Honestly, it's easier to replace the map sensor then to bother trying to clean it/fix it. Go to a junk yard and find an EF, or a newer honda, and steal it's Map sensor. Five finger discount FTW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Your map sensor on the TB is more then likely leaking cuaseing it to idle like that.
Honestly, it's easier to replace the map sensor then to bother trying to clean it/fix it. Go to a junk yard and find an EF, or a newer honda, and steal it's Map sensor. Five finger discount FTW.</TD></TR></TABLE>
yea i will test out a newer map today for sure
so i messed with it more today, and i reset the ecu... and sure enough its throwing a code 5 (map)
im trying to locate on right now but no one seems to have them laying around, so if i cant get it tonight, i will go get one tomorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Junk yards normally dont remove sensors when they throw a car in the yard. Every honda from 92-00 have a TB mounted map sensor, go get one.</TD></TR></TABLE>
yea thats the plan for today
thanks man
thanks man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid »</TD></TR><TR><TD CLASS="quote">
thanks man
so that didnt work
i got one and plugged it in and it still does it
thanks man
</TD></TR></TABLE>so that didnt work
so that didnt work
i got one and plugged it in and it still does it</TD></TR></TABLE>
did you reset the ecu again after you installed it?
so that didnt work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee »</TD></TR><TR><TD CLASS="quote">wiring conversion gone wrong?</TD></TR></TABLE>
what wires are you talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jchung »</TD></TR><TR><TD CLASS="quote">
did you reset the ecu again after you installed it?</TD></TR></TABLE>
yep, still did the same thing just now not throwing a code 3 or 5.
FourthGenHatch
May 19, 2003 10:51 AM
