Whats the horsepower rating on a precision sc61 turbo
Old Apr 3, 2007 | 09:16 PM
IT'S ME DAVID's Avatar
NooB
Default Whats the horsepower rating on a precision sc61 turbo
Looking around for a new turbo and was thinking about the sc61 precision turbo.My setup is a 1.8L 81.5mm sleeved ls block with aftermarket pistons and rods.Looking for a turbo around $1000 and below but also looking close to 700hp rating.Any input is helpful thanks H-t.So far after reading some post this one seems to fit me SC-6176E.
EDIT: I'll also be running a topmount manifold anywhere from 20-28 psi
Modified by IT'S ME DAVID at 10:31 PM 4/3/2007
Old Apr 3, 2007 | 09:25 PM
tony413's Avatar
search search search just about any turbo retailer sales this turbo an has its power range listed with it but looked into borg warner before you settle on this turbo also look at HT members that are using this theres about 2,000,000 or so
Old Apr 3, 2007 | 09:31 PM
NooB
Default Re: (tony413)
yea im reading all the post now.So far this one seems to be the best for my hp rating SC-6176E 680 max rating.
Old Apr 3, 2007 | 09:40 PM
tony413's Avatar
what characteristics are you looking for in the turbo ?
Old Apr 3, 2007 | 09:42 PM
tony1's Avatar
Default Re: (IT'S ME DAVID)
That 680 rating is more of a flywheel hp rating. I've done 655 on a 6176, but it was a rare situation, it was a very good engine combination. 700whp is NOT a realistic number on a 61mm compressor. I'd look more towards a P trim T67 for your goals.
Old Apr 3, 2007 | 09:44 PM
tony413's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">That 680 rating is more of a flywheel hp rating. I've done 655 on a 6176, but it was a rare situation, it was a very good engine combination. 700whp is NOT a realistic number on a 61mm compressor. I'd look more towards a P trim T67 for your goals.</TD></TR></TABLE>
look at the borg warner S362 or S364 and higher they flow over the 650hp mark but they are built more like the holsets in my opinion and for me those turbos rock
Old Apr 4, 2007 | 12:10 AM
NooB
Default Re: Whats the horsepower rating on a precision sc61 turbo (IT'S ME DAVID)
what other turbo will get me close to 700 hp for around $1000-$1200
Old Apr 4, 2007 | 12:14 AM
NooB
from there site i was now thinking of the PT67 or PT63 what have u guys experienced.
http://www.precisionturbo.net/...=3027
Old Apr 4, 2007 | 02:48 PM
NooB
Old Apr 18, 2007 | 11:35 AM
Rod Short's Avatar
We've had customers reach 660-hp at the tire with a 67 compressor wheel and one of our .63 A/R T3 exhaust housings, but he had to push 45-psi to do that -- but that's not a sensible combination for the street. You're really stretching the flow capacity of a T3 exhaust housing. We can put you into a .82 A/R T3, which would help, but we really feel you need a better flowing T4 hosuing in order to give you 700-hp at the tire. New journal bearing PT67 turbos MSRP at under $1,100 and there are better street prices. A ball bearing version would retail at under $1,375. Hope that helps!
RACINTWEEK
Dec 30, 2004 12:57 PM
dk-fabrications
Oct 17, 2004 12:04 AM
CivicSmkYa21
May 19, 2004 10:06 AM
deeweezy
Apr 26, 2003 06:12 PM
2.2
Sep 18, 2002 09:08 AM
