LS\VTEC TURBO HELP WITH P28 ECU
Old Apr 3, 2007 | 08:02 PM
severe97's Avatar
Default LS\VTEC TURBO HELP WITH P28 ECU
So I installed my turbo and DSM injectors with resistor pack and the car won't go pass 3000 RPM's, is this because my p28 ecu is stock...Do I need to chip it? I have a V-AFC.
Old Apr 3, 2007 | 08:20 PM
doood's Avatar
been there done that
Default Re: LS\VTEC TURBO HELP WITH P28 ECU (severe97)
a chipped and tuned ecu would help. but it sounds like you might have other problems.
btw, a vafc is not a good tuning tool
Old Apr 3, 2007 | 08:22 PM
turbociviccoupe's Avatar
Default Re: LS\VTEC TURBO HELP WITH P28 ECU (doood)
if the car is leaning out bad it will feel as if you hit a imaginary wall. like doood said tune will help
Old Apr 3, 2007 | 08:23 PM
severe97's Avatar
yeah..i keep hearing to go with hondata instead..I also heard my stock p28 ecu won't work with DSM injectors...it has to be chipped..is that true?
Old Apr 3, 2007 | 08:31 PM
Tatakai's Avatar
you don't need hondata, if you have a reputable shop with a dyno they should be able to chip and tune you're ecu with chrome/uberdata. however if you really wish to spend and extra (large sum) on hondata then go ahead.
Old Apr 3, 2007 | 08:35 PM
severe97's Avatar
Default Re: LS\VTEC TURBO HELP WITH P28 ECU (Tatakai)
thank you I thought so...do you guys know how much I can boost with the 450 cc DSM injectors?
Old Apr 3, 2007 | 08:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by severe97 &raquo;</TD></TR><TR><TD CLASS="quote">thank you I thought so...do you guys know how much I can boost with the 450 cc DSM injectors?</TD></TR></TABLE>
go with chrome. just my opinion though. your tuner will know how much boost you can do with 450's. he will tell you when the injector is maxed.
Old Apr 3, 2007 | 08:43 PM
severe97's Avatar
Default Re: LS\VTEC TURBO HELP WITH P28 ECU (turbociviccoupe)
good info...I heard from a friend chrome is good...but he said something about only being able to boost no more than 11 lbs..
Old Apr 3, 2007 | 08:44 PM
Tatakai's Avatar
depends on you're motor. is it built? do you have gsr/itr oil and water pumps? if it's somewhat stock i wouldn't suggest more than 10psi on the higher side, a nice 7psi for daily driving. however it's all in the tune.
Old Apr 3, 2007 | 08:49 PM
severe97's Avatar
I have a built motor..9:0:1 compression with titanium valves, arias pistons and the block is sleeved at bensons bored to a 2.0 liter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by severe97 &raquo;</TD></TR><TR><TD CLASS="quote">good info...I heard from a friend chrome is good...but he said something about only being able to boost no more than 11 lbs..</TD></TR></TABLE>
depends on how many bar map you have. go with a motorola map sensor. im boosting 18 lbs on the street with chrome. tuning to 26 lbs at the track soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tatakai &raquo;</TD></TR><TR><TD CLASS="quote">
depends on you're motor. is it built? do you have gsr/itr oil and water pumps? if it's somewhat stock i wouldn't suggest more than 10psi on the higher side, a nice 7psi for daily driving. however it's all in the tune.</TD></TR></TABLE>
depends on the tuner. i have personally boosted 18 psi on gsr,ls, ls vtec. and 16 lbs on my b20vtec. all stock block plenty of people have exceeded that. like i said it depends on the tuning
Old Apr 3, 2007 | 09:25 PM
TegProject's Avatar
the 450 injectors are used stock for 9 lbs so they can't go much more than that. If you have a built bottom end then you are going to want to get some bigger injectors to push some more boost through. If you don't get bigger injectors then there was no point to building your bottom end. Make your money worth it and get some nice injectors.
Old Apr 3, 2007 | 09:26 PM
Default Re: LS\VTEC TURBO HELP WITH P28 ECU (TegProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegProject &raquo;</TD></TR><TR><TD CLASS="quote">the 450 injectors are used stock for 9 lbs so they can't go much more than that. If you have a built bottom end then you are going to want to get some bigger injectors to push some more boost through. If you don't get bigger injectors then there was no point to building your bottom end. Make your money worth it and get some nice injectors.</TD></TR></TABLE>
i boosted 14 lbs on 460cc pretty close
Old Apr 3, 2007 | 09:34 PM
severe97's Avatar
the only reason I installed 450cc is because they came with the turbo kit i bought..should I go with 550cc?
Old Apr 3, 2007 | 09:38 PM
doood's Avatar
use injectors big enough to support the hp you'll be making. so, what's your hp goal?
Old Apr 3, 2007 | 09:41 PM
severe97's Avatar
450 500 max
Old Apr 3, 2007 | 09:44 PM
doood's Avatar
use this to determine ideal injector size: http://rceng.com/technical.htm
Old Apr 3, 2007 | 09:53 PM
severe97's Avatar
right on...that formula looks complicated..but it gave me 707cc..so 700cc injectors..thnaks for the info man
JDM91EF2
22
Dec 23, 2006 02:38 PM
95lscivic
Aug 15, 2006 11:38 PM
badasshatchhh
May 1, 2005 07:46 PM
ludelvr
Dec 30, 2003 09:27 AM
