??? about fuel pumps
Old Apr 3, 2007 | 07:59 PM
HAMSTERHONDA's Avatar
Default ??? about fuel pumps
i am getting my car ready to tune, i still have stock cx fuel pump in the hatch, was wondering what kind of power you guys were making with them before maxing out or seeing fuel starvation, and with what injectors you are useing, this is a na set up, looking to hit 215, i have flaired the hard line and are using -6 line in the bay, and are runnin rc 440s ,any info and help would be great, thanks,
Modified by HAMSTERHONDA at 4:35 PM 4/5/2007
Old Apr 4, 2007 | 09:48 PM
nothing???no one pushed a stock fuel pump???
Old Apr 5, 2007 | 03:34 PM
Old Apr 6, 2007 | 01:32 AM
HerminShS's Avatar
B A N N E D
That fuel pump is not going to feed your injectors, get a walbro 255.
Old Apr 6, 2007 | 11:02 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: (HerminShS)
I have one for sale.
Walbro 255.
75 shipped
Old Apr 6, 2007 | 07:41 PM
not being rude in any way , do you know from experience or seen it happen to some one else, just wanted to know if the pump could supply the demand that i needed, i know everyone uses that same fuel pump, but was wondering if anyone has tried to push the stock pump,with a similar set up, i know the pump is cheap and is easy to install, i put the oem one in my car when i first bought the car,but was wondering if i could get by, thanks for any help, most likely ill just drop one in, incase it does not supply what i need , houston is a long way from sa for the tune,
Old Apr 9, 2007 | 11:56 AM
ReDemoN's Avatar
Default Re: (HAMSTERHONDA)
With that much pressure on a stock pump it will not hold up.
Old Apr 9, 2007 | 05:05 PM
00Red_SiR's Avatar
All Motor Mentor
Do you know how much your stock pump flows LPH? I know the GSR/Si stock pump flows 135 lph which can handle over 400hp. At your power range as long as it flows around 100 lph it should be fine. A 255lph would be total overkill, 190 lph would be as high as I would go on a NA motor.
Old Apr 9, 2007 | 07:25 PM
Jay_Sensing's Avatar
My only thought to add to this and the only reason I put a 255 in mine (other than having one lying around) is that heat kills electric motors over time. Fuel is used to cool the pump as much as be sucked by it and when you have a 16 year old pump that has been ran low SOOOO many times, I would worry a bit about stressing it more by making it need to deliver more fuel. An original pump from that long ago is probably down on it's efficiency.
Old Apr 9, 2007 | 08:28 PM
Default Re: (Jay_Sensing)
Modified by HAMSTERHONDA at 7:51 PM 4/10/2007
turbolsvtecej1
Dec 7, 2012 09:27 PM
lassek20
Jul 9, 2012 02:58 PM
GSE980
Jan 3, 2010 11:42 AM
cjb80
Jun 15, 2004 12:21 PM
I Like Boost
Dec 6, 2002 04:33 AM
