Did a Compression Test.......bad???
Old Apr 3, 2007 | 07:34 PM
yoffer's Avatar
Banned
Default Did a Compression Test.......bad???
Just did a compression test... 165, 171, 185, 175 on cylinders 1-4. Its a D16Y8 with 146000 miles on it. Just want to know if this is good.
Old Apr 3, 2007 | 07:47 PM
turboguy84's Avatar
Default Re: Did a Compression Test.......bad??? (yoffer)
For a really healthy motor they should all be within 5-10 psi of each other. 3 out of 4 cylinders sound nice, but the one with 165 is losing a little compression. It'll be fine if that's what you're asking, just little less performance.
Old Apr 3, 2007 | 07:49 PM
yoffer's Avatar
Banned
well whats the "norm" for a D16Y8 motor? BTW this is the stock motor, it hasnt been swapped or anything.
Old Apr 3, 2007 | 08:02 PM
yoffer's Avatar
Banned
anybody?
Old Apr 3, 2007 | 08:22 PM
doood's Avatar
been there done that
Default Re: (yoffer)
different compression testers will give off different numbers. as long as the numbers are within a few psi of each other you shouldnt worry.
also, did you do the test with the engine warm and throttle wide open?
Old Apr 3, 2007 | 08:34 PM
yoffer's Avatar
Banned
yes, the engine was hot and WOT
cilvia
17
Dec 31, 2023 08:00 PM
wink11290
Jul 6, 2007 07:00 AM
sdinteg
Feb 1, 2005 07:52 PM
SixPAK
Feb 12, 2003 12:33 PM
