Can a Manual ECU start a Automatic car? need help...
well my car won't start and i am trying to narrow down the things that could be causing it.
i have a obd0-obd1 boomslang wiring harness and p28 chipped ecu.
i tired the p28 on a integra and it started up fine.
but then i put the harness and p28 into a DA integra 1991 automatic and it did not start.
so is it the wiring harness or since its a manual it won't start?
Nope. Integras use a seperate TCU to control an Auto tranny. Civics do not. The P28 does not support communication to a TCU. You will need a p75 Auto ecu or you could use a few other integra ECU's with custom components to run the manual ..but bottom line is a p28 isnt gonna do it. I dont deal much with Automatics...but I believe I am correct here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEST1TUNING.COM »</TD></TR><TR><TD CLASS="quote">Nope. Integras use a seperate TCU to control an Auto tranny. Civics do not. The P28 does not support communication to a TCU. You will need a p75 Auto ecu or you could use a few other integra ECU's with custom components to run the manual ..but bottom line is a p28 isnt gonna do it. I dont deal much with Automatics...but I believe I am correct here.</TD></TR></TABLE>
You are partially correct. The P28 ecu will not run the automatic car, but it should still start it. And not all integras use TCU's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">make sure B7 is grounded when in the auto trans car. (clutch switch)</TD></TR></TABLE>
the reason why I said that is not due to the TCU, the P28's B7 needs to be grounded (showing that the clutch is in or auto trans is in park/neutral) to allow the car to start... it will not even turn over if the pin is not grounded.
OMG WTF
11
May 19, 2016 12:35 PM
turbotime
Nov 29, 2003 03:53 PM
