Problems with converted ECU
**THIS IS NOT A BASH THREAD**
Got my ECU from phearable but i dont think it was converted properly as i do not have vtec...can anyone point me to some images of non vtec converted ecu's. Or provide me with something i should be looking for.
look up location C60 or D11 is there anything there? Top left.
also whats the ECU #s example 02d01720 -1500 this is marked on the board, top right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">look up location C60 is there anything there?
also whats the ECU #s example 02d01720 -1500 this is marked on the board, top right</TD></TR></TABLE>
Dont know i will go get the ECU from the car now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">look up location C60 or D11 is there anything there? Top left.
02D01720-1500
and give me a general area for C60
02D01720-1500
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Have you tried contacting Phearable? </TD></TR></TABLE>
Yes, and am waiting for a reply...i know they have good customer service thats why it states this is not a bash thread just looking for some information in the meantime...
so that was a p06. kk, just wanted to know.
see where it says Denshigiken or IPT, one inch down, half inch to the left.
I dout they messesd up, but its possible. are you sure you have a chip that has vtec enabled?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">so that was a p06. kk, just wanted to know.
I dout they messesd up, but its possible. are you sure you have a chip that has vtec enabled?</TD></TR></TABLE>
Ok there is a little jumper thing between the + and the - symbol at C60...the ECU was supposed to come with a base map for a B16b, is there a way to see if the chip is vtec enabled? OR is that somehting you need a romulator for? I guess i will wait to hear back from phearable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">
Ok there is a little jumper thing between the + and the - symbol at C60...the ECU was supposed to come with a base map for a B16b, is there a way to see if the chip is vtec enabled? OR is that somehting you need a romulator for? I guess i will wait to hear back from phearable.</TD></TR></TABLE>
then somone did attempt to chip it. no way to tell if teh chip has vtec other then reading it and opening it with an editor. yup wait to hear from them, good luck.
then somone did attempt to chip it. no way to tell if teh chip has vtec other then reading it and opening it with an editor. yup wait to hear from them, good luck.</TD></TR></TABLE>
Alright man thanks
Alright man thanks
**Update**
Looks like it has to do with me not having a vtec pressure switch. So i need to jusmp a couple of wires in the harness and will be all set.
Phearable has the best customer service. John Vega is very knowledgable...i told him the symptoms of my problem andhe guessed right away. then pointed me t his website where he has direction for jumping the vtec pressure switch.
civic_hatch
25
May 4, 2006 11:16 PM
