01 integra type r miss FIRING!! NEED HELP!!!
ive been bulding up my 01 type r and the bottom block was fully build stright from honda and i put my fully built jdm b16 head on it. The timng seems right but im not sure is there a way or tecnique for me to set up timing correctly. Ive looked in he haynes manual but it doesnt seem to help. I NEED HELP!!!!!!! I DONTWANNA BLOW MY MOTOR
with the white mark by itself on crank pully and pointer on timing cover are aligned , the cam wheels have on one of the spokes each , and arrow with UP written in it , they should be pointing up , haha. and with those arrows up , youl notice in between the 3 wheels at 90 degrees with the arrows , are little flat dashes etched into the cam wheels as well. these should be pointing at one another perfectly. than with 2 pin connector crossed under passenger kick panel , and engine FULLY warm , your timing light on #1 cylinder should flash exactly on the red mark on pully(middle mark of a group of 3). if it doesnt , use dizzy to make it so by loosening bolts , twisting either way it needs , and tightening back up. bang your timed perfectly. did you adjust valves at all? sounds like your exhaust valves could be too tight.
