timing help!!
timing help!!
i pulled the head off my car to change the headgasket, but then got it cleaned and milled at a machine shop... so can i put it back on without a timing light?? are there any tricks to this?? i don't have a timing light, but i would reallly like to be able to drive to work tonite. BTW its a d15b7, so no vtec or dohc. on me for not having the proper tools!
Re: timing help!! (Xsi)
the dist is okay, it wasn't removed from the head, unless the shop did but im assuming they would put it back on properly. im just trying to figure out how to time the cam to the crank... do i put the crank at tdc and the cam gear marking that says "top" up (if so how do i kno when the crank is tdc, im sure there are markings but im not home or with my haynes manual so help me out)
LoGaN-VanG
13
09-27-2011 05:27 PM
