Im Haveig trouble with my idle
I turn the car on idles high to low for about 5 to ten seconds then evens out Ill let it run for about 3 to 5 min then It just shuts off I wanna get the motor to run smooth and steady before I finish putting in my turbo setup on Its the only thing holding me back and its has a delayed throttle response but i have no check engine light i changed the map and tps no diffrence i changed to another throttle body same thing im wondering if the the sensor that bolts to the back of the intake manifold could be the problem or possibly the one near the fuel rail those are the ones i didnt try yet but ill let you know exactly my setup to see if anyone else had the problem
gsr motor skunk 2 intake manifold stock ls throttle body hondata manifold gasket ? any help appreciated
jwamp316
22
Feb 7, 2005 01:08 AM
