Question about rods...
I bought some forged rods for my d16z6 over a year ago and never got around to using them.....now today I had some stock b16a rods show up and they are nearly identical....My question is could I use my forged d-series rods in my b16?
a mm or two makes ahuge diffrence, it will cause the car to have NO power or the motor wll explode from the piston hitting the head. these motor's don't exactly have a lot of rom to play in them. trust me, not just the length is neccessary to mount those rods in the motor, you also have to take into account piston pin size, crank end girth, and bearings. do the rods even use the same size crank (journal diameters) I suggest not using htem, but if you do, please post pics of the motor after you destroy it trying to turn it over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">I will tell you they are within a MM or two....</TD></TR></TABLE>
well I will tell you that if you are not even sure, then I wouldnt even use it.
the pin diameters are different
d16 rods are 137 mm length
b16 rods are 134 mm length
it changes the compression, r/s ratio ect
if you have any ?? regarding certain rod lengths try http://www.zealautowerks.com
& plug in the #s
& plug in the #s
Kendall
14
Mar 1, 2023 07:16 PM
JustinG60
May 8, 2005 05:54 PM
