Gauge cluster problem!
So i tried installing a Vtec light so after everything was done and said... the RPM, Speed meter, Gas, and Temperature doesn't work anymore. Lights work on the cluster and turn signals work just fine. Starting up the car the check light doesn't come on no more. Whats the problem and how can i solve this. This is bringing me lots of headache
Edit: Cluster is 99-00 Si
The lights on the cluster still works and the signals still work... i don't understand why none of the gauges are working.
Yes i did, i made sure everything was in tightly. Thats why the lights work but not the meeters. I don't get why all the gauges would be dead...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Simple questions..... did you check your fuses? </TD></TR></TABLE>
Fuse!? what fuse? i didn't know there was a fuse to the cluster. Where is this fuse located?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">What exactly did you do to the cluster to wire said Vtec light in?</TD></TR></TABLE>
Took the frame apart and put in a light for when vtec engages, the light turns on. I used an empty slot next to the engine check light.
