Thinner Head Gasket= higher compression ? ? ? ????
Old May 26, 2002 | 07:48 AM
you2envious's Avatar
Default Thinner Head Gasket= higher compression ? ? ? ????
Ok I read this in a previous post , and was alittle shocked . I am still learning ins and out of somethings on engines but I know basics . My question is how does changing the head gasket change your compression ? ? ? ? If I changed my head gasket on my d16y8 how much of an increase on compression would there be ? ? Would there be a noticable change in performance when combined with Intake , exhaust and advanced timing etc etc ? ? ? ? ?
Old May 26, 2002 | 07:56 AM
JV's Avatar
JV
Who?
Default Re: Thinner Head Gasket= higher compression ? ? ? ???? (you2envious)
http://www.bojangs.com/calculator/
Old May 26, 2002 | 09:41 AM
Pat McGroin's Avatar
Default Re: Thinner Head Gasket= higher compression ? ? ? ???? (JV)
i thin an explanation is given on the spoon sports website
[Modified by JDM Dasilva, 10:41 AM 5/26/2002]
Old May 26, 2002 | 12:04 PM
underrated99si's Avatar
Default Re: Thinner Head Gasket= higher compression ? ? ? ???? (JDM Dasilva)
changing head gasket is same as milling the head closer you get the pistons to the head the higher the compression on the motor
Old May 26, 2002 | 12:05 PM
Doctor CorteZ's Avatar
the smaller the combustion chamber is the more compression there is
thinner gasket makes the block and head closer together , thus a smaller comb. chamber
Old May 26, 2002 | 12:09 PM
hybridreams's Avatar
Right, more pressure...get it now? Oh, and it's not just by changing the head gasket. It has to be a thinner head gasket for this to work. Stock won't do anything and a thicker one will lower your compression.
Old May 26, 2002 | 01:28 PM
Default Re: Thinner Head Gasket= higher compression ? ? ? ???? (hybridreams)
(((LIGHT BULB LIGHTS UP)))) Cool I gots it , thanks for the feedback . But if I do this how much might I gain in compression ? Will it be a slightly noticible gain ? ? ? , similiar to the gains seen in a intake or exhaust ?
[Modified by you2envious, 5:29 PM 5/26/2002]
Old May 26, 2002 | 06:26 PM
depends on how thin you go
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
tegasaurus
Dec 23, 2003 02:54 PM
tek_civic
Nov 8, 2002 10:52 AM
B18CRacer
Jan 29, 2002 11:39 AM
