need some help check engine light p0171
been getting a cel 45 or when i run a scanner p0171 which says i'm running lean on bank 1 its a 98 gsr with i/e. i've changed out the primary o2, new plugs and a new fuel filter. Cel will flip on after 30-40 miles after its been reset. any ideas ?
Is this a stock tune? Check for vacuum leaks. Any FPR's or other mods besides I/E? AEM fuel rail, etc...?
I used to get that running 310cc injectors when my piggyback ECU (eManage) did not have the RPM wire plugged in. It was running way rich.
I would hook up a wideband O2 and check the A/F readings, but you proboably don't have access to that.
p0171 System too lean. Comes on after two consecutive trips where a lean condition has occured.
Fuel supply: Fuel Pump, FPR, Fuel Filter, Injectors
Primary HO2
MAP Sensor
Contaminated Fuel
Valve Clearance
Exhaust Leakage
Improperly tuned ECU
Vacuum leak
Troubleshooting in order from shop manual:
Fuel pressure?
PHO2S stuck outside 0.3 - 0.6 Volts?
Evap Purge Control Solenoid hold vacuum?
Valve clearance in spces?
Replace Fuel injectors (or flow test)
It doesn't say in the manual, but my next step would be to try another ECU and check the MAP sensor.
http://www.hondahookup.com for manuals.
Primary HO2
MAP Sensor
Contaminated Fuel
Valve Clearance
Exhaust Leakage
Vacuum leak
Fuel pressure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th »</TD></TR><TR><TD CLASS="quote">p0171 System too lean. Comes on after two consecutive trips where a lean condition has occured.
Primary HO2
MAP Sensor
Contaminated Fuel
Valve Clearance
Exhaust Leakage
Vacuum leak
Fuel pressure?
map sensor on Snap-On scan tool was reading according to factory specs
We have been through all this already thats why we are asking. The car had a Jackson kit before and I think that the injectors are @ a different CC than a GSR 240cc but no way to tell. Slain compaired the GSR w/another and Injector color was the same white dot, the FPR was not. We swapped out FPR this saturday and cel back on next is swap Injectors today and see. Next will be fuel pump. cross your fingers.
https://honda-tech.com/zerothread?id=1890859 this guy has o2 sensors for cheap denso ones at that as well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th »</TD></TR><TR><TD CLASS="quote">Why was the fuel pressure low/high?</TD></TR></TABLE>
because someone put the wrong FPR on it was only allowing the fuel pressure to get to 38psi. In turn setting light for lean conditions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain »</TD></TR><TR><TD CLASS="quote">Cars driving great Will...thanks for all the help. Mom said the accord felt peppy again fack those autolite plugs lol</TD></TR></TABLE>
good now we can move on to the beast motor for that GSR
Circaskaterr
28
Jan 28, 2016 09:31 PM
fitbmx86
May 20, 2007 04:59 PM
