Check Engine Light turning on/off...
Old Apr 2, 2007 | 10:54 AM
jamzm101's Avatar
Default Check Engine Light turning on/off...
Hello,
I am a bit concerned, I have an 05 V6 Accord and recently discovered that if I put the pedel to the metal the "check engine light" tuns on. Once I easy off the gas the check engine light turns back off and all is fine.
This only happens when I'm on the freeway and I step on it causing the tranny to go into it's passing gear and the car red lines a bit.
Is it normal for the check engine light to turn on because of this?
Old Apr 2, 2007 | 12:00 PM
philadd's Avatar
Default Re: Check Engine Light turning on/off... (jamzm101)
No, it's not normal. The ECU might have a code stored, even though the CEL isn't staying on. Take the car in to the dealership if you're under warranty. Otherwise take it somewhere and have the codes checked.
TeamSumner
Sep 29, 2014 05:14 AM
NewEra
Jul 20, 2009 08:13 PM
98teg
Oct 6, 2003 07:39 PM
VTECVillain
Jan 6, 2002 11:40 AM
