tuned dry (50 shot of nitrous) w/ OEM B16a2
Old Apr 2, 2007 | 08:24 AM
water:injection's Avatar
Default tuned dry (50 shot of nitrous) w/ OEM B16a2
Im going to be tuning with AEM EMS stand alone EM but im wondering if i can be safe to spay a 50 shot repetivley. Will i run into any problems with stock internals? such as melting, detonation, cracking a ring land etc. or pre-mature engine problems....
Old Apr 2, 2007 | 08:41 AM
envee's Avatar
no way. go bigger.
Old Apr 2, 2007 | 09:04 AM
Probot's Avatar
make sure your diamond plate floorboards are welded down good..lol jk
Old Apr 2, 2007 | 09:09 AM
ARMED's Avatar
50 is alright...
depends on how long you use it....
i used 80-100 before...1 of my valves melted and all the spark plugs..
thats spraying from second to fifth gear...all the way...and got some gouges on the bore...we did it in purpose
50 is good i guess for a short period of time
Old Apr 2, 2007 | 10:11 AM
t0p_sh0tta's Avatar
Default Re: tuned dry (50 shot of nitrous) w/ OEM B16a2 (water:injection)
You're going to waste a $1000 standalone ECU on a stock B16 w/ a dry 50 shot???
Follow the directions for the N2O kit and knock yourself out. You don't need a tune with that.
Old Apr 4, 2007 | 08:12 AM
Default Re: tuned dry (t0p_sh0tta)
thanks 4 the replies... I am planning on using the ZEX from 2nd gear to the top of fourth. Shouldnt it hold or will it melt like armed said?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">You're going to waste a $1000 standalone ECU on a stock B16 w/ a dry 50 shot???
Follow the directions for the N2O kit and knock yourself out. You don't need a tune with that.</TD></TR></TABLE>
YES, im getting the AEM tuning its on its way right now. the reason is because im going turbo and i need one anyways.
so will anything happen i run a 50 shot safley... i just want to hear theorys or anything.
Old Apr 4, 2007 | 09:27 AM
ken00si's Avatar
Default Re: tuned dry (water:injection)
I had a Zex wet kit and ran a 50 shot from 1st through 4th and never had a prob. Not really sure why you are going to start in 2nd???
Read the directions and retard the timing 2 degrees or it will detonate prematurely. Enjoy!
Old Apr 9, 2007 | 08:15 AM
yeah im thinking i'll be safe using a 50 shot for a DD.
i just need to get up to speed when entering the freeway you know what i mean.
Old Apr 9, 2007 | 08:29 AM
MurdersV8s's Avatar
Default Re: (water:injection)
So you are going to use nitrous on the freeway. That is not a good idea IMO. Keep it on the track so you can only kill yourself.
hoffmanb16
11
Mar 11, 2009 12:01 PM
Civic Hybrid
Feb 23, 2007 08:36 AM
175Shot4Door
Jan 21, 2006 05:54 PM
cshky
Oct 4, 2004 03:21 PM
shift6
Oct 17, 2002 04:49 PM
