rear alignment?
ok i have a 97 lude and wondering if we need to have our rear wheels align?..or is it usually only the front needs to be align?.after having me car lowered. les schwab has a Thrust alignment which is 50 bucks and the 4 wheels alignment for 75 bucks.. is the 4 wheels alignment needs?.. need info..Thanks
imo i dont think you need to worry about your alignment as much as a camber problem depending of course how low you went. of course someone will jump in to add more info i bet
2 wheel alignment is basically worthless, unless you recently did a 4 wheel, then altered only your front suspension. You align the front off the rear, so if your rear is out, aligning the front will most likely make everything worse
